Me and my friend have just assembled a newly bought system, but we've run into some trouble. By turning the machine on, no image is on the screen and the computer reboots every 10 seconds. The strange thing is that if we put his sound card in, power up, let it restart 1 time, remove it and power up again it starts normally into windows.
It has also happened that the computer would restart while in windows with no BSOD or anything.
His specs for the system are:
Asus p5e3
Intel Core 2 Quad 9450
Xfx 9800GX2
2x2gb Corsair XMS3 DHX
550W Corsair powersupply
The sound card is a Creative X-fi xtreme music
His onboard sound has been disabled(in one of the few succesfull bootups)
Your system doesnt have enough power.
9800GX2 requires a Minimum of 580W from you PSU not to mention at least 40 amps on the 12 volt rail.
(remember the gx2 is technically like having sli so imagine dual 9800s and the power requirements)
Random restarts and reboots are almost always a psu problem.
basically whats happening is when you take out your sound card your giving it barely enough power to startup, once in windows the card begins to heat up and once it gets warm enough and the fans kick up it overloads your psus peak power and shuts down. this is why your system is having trouble. get a 700 or better watt psu and you should be fine.
Message edited by vegettonox on 08-07-2008 at 11:32:10 AM
------------------------------"whats going on with the leg"... "first you tell me whats going on with the boobs" Greg House. (house md)
Reply to vegettonox
The thing is, that we have assembled a similar system that works perfectly.. the only diffference is that the other system has a Asus p5e and DDR2 ram. same powersupply and graphics card
At idle your Q9450 and 9800GX2 are probably using less then 200 watts so I dont think its your power supply.
Have you tried using just 1 stick of RAM at a time? Rotate the sticks till you have tested both in both the first slot and 3rd slot of the motherboard.
I do admit i was going by their recommendations on power but it could still be a power issue just maybe not a watt based one.
-also you might want to try these
a. disconnect all peripherials such as cd drives and hard drives and take out all but 1 stick of ram, your sound card and start the system. see if it gives you any sort of beep codes or if it boots ok.
b. if not try a cmos flash find the jumper labeled j5 and while the system is off short it out for about 20 seconds and then take it back off and restart your computer.
You need to locate what part is causing the problems. since you said the only differences is the motherboard and ram start with those. which leaves you with ram at this moment. test the ram sticks 1 at a time.
if its memory related your memory might be being misconfigured by the bios when reading its spd. from what your telling us it can really only be 3 things. the ram, the motherboard or the power supply. (did the other system use this processor as well ?)
(btw what version of windows are you running. if its xp and your not getting a bsod it probably is still the psu. thats a big red flag if your not getting a bsod. if its windows vista this is normal because by default vista will restart automatically and not normally show you a bsod.)
until you test the ram and psu and get back to me there are still a couple other more in depth problems it could be like the ram configuration problems. it is overclocked
