Yes No
Ads
Tom's Hardware > Forum > Storage > Hard Drives > [Solved] How do you move data from old PC to new PC? Help!
Forum Storage : Hard Drives [Solved] How do you move data from old PC to new PC? Help!
Best answer from .
Hello all
I've tried searching for answers, but i figure you guys must know. How do i easily move pictures, movies, itunes to the new PC? Install the old HD as a "slave?" Transfer via a USB cable? I am going from XP to Win 7 also.
TIA
Damien
Reply to damien12g
Best answer
I would favour installing the old drive as a secondary because it's quick. But be sure to create a folder on the new drive called something like old stuff and transfer the old stuff into that.
If you don't fancy dismantling -- a network connection is complex if you haven't done it before but relatively quick.
In any case I think Windows has anticipated the scenario and provided a facility in Windows for just that.
Reply to Anonymous
Another way is share your old PC drive/folder on the network. On the new PC access the share drive then move the file to the drive of the new PC. This solution no hardware activity is required.
Installing the old HD as a slave is a less troubled approach. You can remove the old drive after the file transfer.
Reply to leon2006
That's what I do - pull the old hard drive and install it, either permanently or temporarily, in the new computer.
Reply to jsc
Hi I was wondering if you could help me out here! I have two towers and would like to take my old hard drive in install it into my other tower! however im not sure what steps to take ! could you please help me out?
Reply to angelica26
Start a new thread please.
------------------------------ http://i1123.photobucket.com/albums/l546/area51reopened/Moderator1-1.jpg
http://valid.canardpc.com/cache/banner/2383852.png
Reply to Area51reopened
This topic has been closed by Area51reopened
There are 1493 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Connecting a Laptop Hard disk directly to Desktop (SATA)
By RetiredChief, 5 hours ago:
fantastik250 - Sata interface is only for data. Does not adjust any voltages. power is...
Best offers
Top experts
