Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Monitor problem any advise welcome
Forum Graphic & Displays : TV/Video Cards - Monitor problem any advise welcome
Well i went and bought a iiyama 514 22 crt monitor of ebay had to have it sent by post arrived ok no viz damage but
and i think its dead
problem ;green power light comes on but screen stays blank no degaus
you can feel the heat on top back vent after 20 mins or so and when turned on you get a short sizz and then nothing swaped the the cables and tried another pc reduced refresh rates etc NADA.
SO ANY IDEAS OF FIX APART FROM BINING IT LOL
Thanks
Sponsored Links
It is possible that monitor doesn't accept your graphic adaptor's resolution/frequency.
Solution: Plug-in other monitor (possibly the one working recently) and change resolution/frequency to lower values (ex. 800x600 / 60Hz).
Reply to mobibarbara
Definatly what the above poster said, CRT monitors dont support resolutions as high as LCD and plasma screens and some other newer monitors do. Change it to a very very low res.
Reply to blackhawk1928
heres the spec if that helps i tried all that but no joy thanks for your help
Display Type Display / CRT
CRT Type Diamondtron U2 - aperture grille
Built-in Devices USB Hub
Width 49.3 cm
Depth 50 cm
Height 47.9 cm
Weight 29.5 kg
Display
Diagonal Size 22"
Dot Pitch / Pixel Pitch 0.24 mm
Max Resolution 2048 x 1536 / 88 Hz
Max Sync Rate (V x H) 200 Hz x 142 kHz
Video Bandwidth 390 MHz
Controls / Adjustments Brightness, contrast, H/V moire, H/V position, H/V size, gamma correction, rotation, trapezoid, convergence, degauss, colour temperature, parallelogram, pincushion, pin balance, zoom
Display Screen Coating ARAS screen treatment
Signal Input 2xVGA
Features Dual Beam Focus
Image Colour Temperature Adjustable
Image Brightness 200 cd/m2
Video Input
Analogue video Signal RGB
Audio Output
Type Speaker(s) - integrated
Output Power / Channel 1 Watt
Expansion / Connectivity
Interfaces 2 x VGA - 15 pin HD D-Sub (HD-15)
1 x audio line-in - mini-phone stereo 3.5 mm
1 x USB upstream - 4 PIN USB Type B
4 x USB downstream - 4 PIN USB Type A
1 x headphones - mini-phone stereo 3.5 mm
Miscellaneous
Cables Included 1 x VGA cable
1 x audio cable
1 x USB cable
Compliant Standards FCC Class B certified, CE, TUV GS, DDC-2B, DHHS, EPA Energy Star, PTB, TCO '99, VESA DPMS, UL 60950, CSA 22.2 No. 60950
Power
Form Factor Internal
Voltage Required AC 120/230 V ( 50/60 Hz )
Power Consumption Operational 170 Watt
Power Consumption Stand by / Sleep 3 Watt
Manufacturer Warranty
Service & Support 3 years warranty
Service & Support Details Limited warranty - 3 years
Environmental Parameters
Min Operating Temperature 0 °C
Max Operating Temperature 35 °C
Humidity Range Operating 10 - 80%
Reply to storm1964
- 0 +
might be just a dead monitor...but try what the above said first just to make sure. I m having problems with my CRTS atm might be my GPU at fualt through :/
Reply to AMG
There are 1309 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
