Help me pick out a good case for these parts!
  • New Build
  • Cases
  • Cooling
  • Power
  • Systems
Last response: in Systems
August 7, 2008 6:24:38 PM
2X2 Gig DDR2 http://en.wikipedia.org/wiki/DDR2_SDRAM -800 - http://www.newegg.com/Product/Product.aspx?Item=N82E168... $77.99
E8400 - http://www.newegg.com/Product/Product.aspx?Item=N82E168... $174.99
P5E Deluxe X48 MB - http://www.newegg.com/Product/Product.aspx?Item=N82E168... $219.99
2 X HD4850 CrossFire - 2X http://www.newegg.com/Product/Product.aspx?Item=N82E168... $192.99
After Market Cooler. - http://www.newegg.com/Product/Product.aspx?Item=N82E168... $36.99
Cooler Bracket - http://www.newegg.com/Product/Product.aspx?Item=N82E168... $6.99
And a good Power SupplyPC Power & Cooling S61EPS 610W - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Plz provide me with a proper casing, for these part... Although i need a proper case for these parts, i'd also like it to look a bit nifty almost like an alien ware or a clear case would be nice thanks =D
More about : pick good case parts
August 7, 2008 7:21:19 PM
Yeah it would hold that stuff, but the 80mm fans seem kinda not good. To get the same airflow of a 120mm fan, they will have to blow harder which means more noise. It also doesn't really look very sturdy to me, but I'm really no expert on cases. However, it is cheaper than the ones I mentioned.
August 7, 2008 7:24:44 PM
Yeah, do you know of any cases aroudn that price, or cheaper than the ones you were providing!?
thanks =D
August 7, 2008 7:28:12 PM
I really only know about the one that I have and that is the Antec 900. Many times Newegg will offer rebates on it and I've seen it as low as $70. I don't really have any other recommendations as I haven't used or researched many others.
