Hi all,
I recently Built my computer with the following parts
E8500 Core duo2 3.2
Inno3d 9800GTX+
XFX Nvidia 750I SLI Motherboard
Sata2 Seagate HD 16mb cach 320gb
dvd rw drive
arctic cpu cooler
700w PSU
4gb 800mhz OCZ DDR2 Ram
Vista 32
I installed windows and it would crash every now and then with blue screen varying messages, then when I would install the latest mobo chipset drivers it would make the system more unstable and the type of messages I would get would be things like memory leak, out of physical memory, fault codes like 01000XFFFF , 010000064 etc, sometimes even just trying to load Vista would sometimes crash, and then inside windows vista system info it would not know how much ram or what cpu was installed, it did at the beginning, all my voltages were fine too
Then my system would not boot at all, no beeps or anything and an error code on the mobo d4, I swapped the ram around and it made no difference.
My mobo is being replaced tomorrow by a XFX 780I as the place I got my mobo from had no 750Is in stock, its just I would not expect it to be the CPU or the Video card,
No overclocking or nothing either, all stock
E8500 Core duo2 3.2
Inno3d 9800GTX+
dvd rw drive
arctic cpu cooler
700w PSU
Vista 32
