Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Problem running Riddick EFBB on 4870X2
Forum Graphic & Displays : Graphics Cards - Problem running Riddick EFBB on 4870X2
I just installed Riddick - Escape from Butcher Bay and at first everything seemed fine. The meny and intro movie and all worked fine. But as soon as I gained control of the character the screen turned full of vertical stripes. Extremly thin stripes in sand yellow colors, not lime green and pink and so on as they use to be if there is a problem with drivers or whatever.
I have both Crysis and Oblivion installed and they work fine. So there should'nt be a problem with the graphic card or any drivers. And I have hade Riddick installed on XP before, and it worked fine. Now I have Vista x64 installed.
So is it the graphic card or the OS that is the problem? Anyone else having problem with Riddick that has a 4870X2?
Thanks! I appreciate it!
Sponsored Links
I remember an opengl fix that was released for the game
------------------------------ Amd x2 6400+ @ 3.5ghz | Ati 3870 | 3gb ram
Reply to vip3569
There are 1051 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
