Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > 24 inch WS monitor who's DVI port does not have HDCP
Forum Graphic & Displays : TV/Video Cards - 24 inch WS monitor who's DVI port does not have HDCP
Hi all, can anyone recommend a good 24 inch wide screen monitor who's DVI port DOES NOT have HDCP?
thanks
Sponsored Links
Why do you need one without HDCP?
Reply to cjl
- -2 +
so that if i download pirated videos from the internet or watch a DVD i copied, or anything with copy protection, that i will be able to watch it.
Reply to velocci
HDCP only apply for materials with that are copy protected....
Non-copy protected materials should play just fine...
You need to make sure that whatever video you are to play don't require HDCP-compliance hardware & software.
There are tools in the internet to disable HDCP requirement on copyright protected materials.
Buy the best LCD display with your money and use the available software tools from the internet to play your video.
The other option is use component-video as link from your video card to your TV. Component video can display 1080P just like HDMI. Its there is a difference in quality its something that most of use won't notice.
I tried both Component Video and HDMI to play Blue-ray and HD-DVD. Both work with 1080P. The quality is almost identical that if there is any most people won't notice.
Hope this help
------------------------------ Q6600: Maximus Formula: Zalman 9700LED8GByte: Crucial Ballistics 4-4-4-12: PC6400; Vista Ultimate-64BFG XOC 4890; Disp: 70 Inch HDTV: Hauppage 2250 HDTV Tuner1.4TByte: 2x750Gbyte; RAID0; Case: Antec 900: PS:Antec Quatro 850
Reply to leon2006
- 0 +
are you saying that if I have an LCD monitor that doesn't have the HDCP, I won't be able to play videos that require it HDCP-compliance hardware and software?
Reply to velocci
You will be able to play them (if you haven't bypassed the compliance check) but it will be in a lower resolution.
Strange how all the doom mongerers about Vista and HDCP seem to have gone away - doesn't seem to be an issue any longer.
You should check to see if any publisher (Sony etc) has actually enabled this form of protection in their DVDs / Blu-Rays etc. I think you will not find any.
Reply to The_Abyss
Velocci....
Materials with copy-right protection enabled (HDCP Enabled) such as Blue-ray, HD-DVD require HDCP compliant Hardware and Software. You can't play these videos/audio at full 1080P without HDCP compliant hardware & software.
If your Hardware/software is not HDCP compliant, videos with copyright protection (HDCP required) will only play at regular-DVD resolution (480P)
Reply to leon2006
There are 592 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
  • 01:00 dpnaugle won the Freshman badge
