GeForce 6200 help!
Forum Graphic & Displays : Graphics Cards - GeForce 6200 help!
I have a dell Dimension E520 and it came with the Intel 965 graphics card on the motherboard. I went to slightly upgrade it for my 8 year old son to play games on the computer. I installed the GeFroce 6200 in the PCI slot with no problems. When I turned on the computer I had no power at all! No fans nothing. Just a little orange flashing light on the power button of the computer. As soon as I take the graphics card out my computer works fine. I called EVGA and the guy suggested that I did not have enough power(i only have 305w) and that i get a bigger power supply. SO idid that today, 650w, installed that no problem. Tried the graphics card and have the same thing happen! Is it the card, my computer? Do i try another card? Help please!! I can install all of this with no problem would just like to have an updated working graphics card!
Thanks!!!
Sponsored Links
Where did you get the 6200? o.O
Anyway, make sure u have everything installed properly to the MoBo: RAM, PCI slots and cables in general get loose sometimes.
Also, go into your system's BIOS and disable the onboard card.
Besides that, i don't know what could be the issue...
Esop!
Reply to Yuka
Strange. I assume your computer has a PCI-express video card slot? When reading about your system online it looks like your expansion slots are pci and a PCI-Express 1x slot.
It many be that the video card can not be used in that slot. That is the only thing I can think of. Your power should be more than enough. Just make sure the video card does not have a power plug in the back. I had an old 6200 AGP card that needed extra juice, but I don't think the PCI express cards did.
Also make sure you have your on-board graphics disabled in the bios and that the bios is using the PCI-express slot. Then try it.
If not then it could be a conflict with the video card not being a 1X but maybe some one else might have some suggestions.
Have you checked with Dell support?
Good Luck! ;)
------------------------------ Athlon 64 AM2 6000+
Gigabyte M61P-S3
4 GB OCZ Fatal1ty DDR2 800
Asus 4850 512mb
Reply to caamsa
if the system would turn on but not POST, that's one thing, but if the computer doesn't even turn on, then something is not right. but i cant understand why it wouldn't. with a 650W power supply, there not being enough juice is out of the question. the only possible cause of the problem would be the card. if you can, try it in another computer. and if it still wont work, then send it back to EVGA.
Reply to Nik_I
i disabled the intel one first and there is no pwer plug for the video plug i lokked because my new power supply has a lug for the PCI express, if i have a pci is it possilble that I am putting it in the PCI express? there is only one place that the card will fit so that is where i out it, nothing is loose... I got the card at circuit city. i did not check with dell support yet, my experience with them is every conversation is at least 45-60 minutes!! i thought someone on here may know something first!!
Reply to gatormidwife
gatormidwife wrote :
i, if i have a pci is it possilble that I am putting it in the PCI express?
nope. your computer only have a pci-express x1 slot, which is a very small connector, much too small to fit a standard pci card in it.
in this picture, you can see both connectors:
http://aphnetworks.com/review/asus_p5e3_deluxe/009.JPG
the very small white one is the pci-e x1 slot, and the longer white slot in between the blue and black ones is a pci slot.
Reply to Nik_I
And no, u can't put a PCIe card on a regular PCI slot without an adaptor.
It's a weird problem indeed, hope u can solve it.
BTW, did u get this one?
http://www.nextag.com/BFG-Technolo [...] 91C8D07061
Esop!
Reply to Yuka
yep, that's the one i got! And yes i see how i could not not fit it in the pci-e
Which model Dimension E520 do you have? I know they can come in several different configurations.
Gigabyte M61P-S3
Asus 4850 512mb
Reply to caamsa
now that u pose taht question i decided to look up my computer online at dell and this is what i got...
http://www.dell.com/content/produc [...] l=en&s=dfh
So it looks like a graphic card is supposed to go in a pci-e slot? is this possible if there are pci slots available? and do i now have a good case to return the card to circuit city since no one there was helpful to start with?
one more stupid question since i am beyond frustrated! is there a difference between pci-e and pci-e x 16?
Size.
Look at the picture shown by Nik_I.
The long blue ones are 16x the lil' white in between is x1. The other long whites are regular PCI.
On your rig link, i can see a x16 PCIe. You should pro'lly buy a PCIe card if u can.
Cheers!
Reply to Yuka
Yuka wrote :
Size.
Cheers!
Agreed......
Expansion Slots
PCI: 2 Slots
PCIe x1: 1 Slot
PCIe x16 (Graphics): 1 Slots
Get a PCIe video card. Go on newegg you can get a much better video card than the one you have for probably the same amount of money.
Gigabyte M61P-S3
Asus 4850 512mb
Reply to caamsa
Thanks to everyone for your help! All the comments helped me brainstorm and it was that the graphics card needed to go in to the PCI-E x16 slot. I got one and it is up and running great!!!
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > GeForce 6200 help!
There are 1282 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
