Hi there! I've already gotten quite an education reading these boards over the last few days and appreciate it. I've gotten the sudden urge to build a nice computer, mostly for games. I currently play Lord of the Rings and COD4. I did build a computer years ago but have not been keeping up with technology much. Over the last few days I have been trying to catch up. Here is the list of components I have come up with and I would love to know before I order if I'm forgetting anything important, if everything looks reasonable and compatible, and if there are any other little bits and pieces I need to order. Thank you in advance for any comments or advice! In particular I'm wondering if I need a cpu cooler or if the stock one is ok. I will probably eventually try overclocking the e8400 to 3.6 ghz, which from what I understand so far is quite conservative. Thank you!
note: I don't ever seem to use much hard disk space, but I am getting two thinking to put the operating system/swap file on the smaller one and games on the other.
However change the motherboard to an ASUS or GIGABYTE board,go for P35 if u need single card or go for X48 if u need dual cards.
For RAM,i say go for a DDR2 800 RAM with 4-4-4x or lower timings because the difference between DDR2 800 and 1066 isnt much and DDR2 800 OC's very good too.
------------------------------Q6600@3.4+ TT V1 Cooler,SAPPHIRE HD 4870X2,ASUS MAXIMUS FORMULA,4GB OCZ DDR2 800,LG W2452V 1920x1200
Reply to Maziar
Hi
I second Maziar he's right on just about everything. But also are you getting SATA cables for looks otherwise there are always some bundled with the MB.
------------------------------Core 2 duo E6750@ 3.72ghz,Geil ultra 2gb 800hmz @1050mhz 5-5-5-15,
Asus P5K mobo,74gb raptor,250gb WD sata hdd,
His ICEQ 4 4850 512 Turbo,Pioneer sata 18X dvd writer,
