Tom's Hardware > Forum > Homebuilt Systems > New System Build > Need Advice for building a best price for power gaming system
Forum Homebuilt Systems : New System Build - Need Advice for building a best price for power gaming system
Hey all, I've built a handful of systems over the last several years. I am currently looking to upgrade my current cpu with a new motherboard/cpu, video card.
I've toy'd with the idea of sli and using 2 lower priced cards to get better performance than a high end but my knowledge in this area is lacking......I am open to intel or amd type systems.......
I am looking for best performance for the price.....somewhere around 250-350 dollars.....I do have the ram, hard drive, etc.......
Thanks for the help!
Sponsored Links
250-350 for the video card(s) only, or the MB + CPU as well?
Most of the time SLI/Crossfire is not a way to get performance for cheaper, it's either an upgrade path or a way to go further than what a single card can do.
What resolution will you be gaming at?
What is the RAM you have, DDR2-800?
------------------------------ The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. - Rebec of Ginaz
http://valid.canardpc.com/cache/banner/600609.png
Reply to Zenthar
The ram is DDR2-800, probably somewhere along the lines of 150-200 for motherboard/cpu and 100-150 for video card....... I don't think i really need the benefits that come with that setup
Reply to boomer76
your looking like a P5k or P5Q for mobo and a E2200 or e7200 for cpu in your budget. And get a 4850 with mir for GPU.
Message edited by roadrunner197069 on 08-09-2008 at 11:09:17 PM
Reply to roadrunner197069
- 0 +
For that price, you will not get a "power gaming" system, but an entry-level system. For that price, I would suggest an AMD setup, unfortunately, I don't know much about AMD boards, so have someone double-check what I say :P.
With that MB, you even get Hybrid CrossFire with the on-board GPU to give the 4850 card a little boost. Total: 363$, but you are getting 2 free games with that at NewEgg (1 with CPU, 1 with GPU).
Reply to Zenthar
There are 828 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
