Tom's Hardware > Forum > Motherboards & Memory > Memory > Is my 1066mhz RAM running at what it should be?
Forum Motherboards & Memory : Memory - Is my 1066mhz RAM running at what it should be?
Is my RAM running at what it should be?
http://img65.imageshack.us/img65/4883/mem2cs5.th.jpghttp://img65.imageshack.us/images/thpix.gif
I have the CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500).
Shouldn't it be 5-5-5-15?
Also when i look in the bios the default is 5-7-7-24 with 1.80v......... Soooo weird!
q6600 @ 3.0
Gigabyte EP45-ds3
Antec 650w
Message edited by SaveMeInternetz on 11-22-2008 at 05:18:16 PM
Sponsored Links
You can go into the BIOS and manually adjust the timings. Most BIOS's will not correctly identify 1066 Ram speeds. They are technically overclocked. Not that it is going to make much difference anyway.
Reply to jitpublisher
I'll run memtest and just see what happens @_@
Reply to SaveMeInternetz
Memtest only tells you if you have defective ram or faulty. Just do what jitpublisher said and then run Memtest.
Reply to Ragsters
I was just wondering as well is it safe to continue my RAM at 5-7-7-24 with 1.80v?
I also ran memtest for 7hours with these settings and no errors
There are 1211 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
