Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Evga 780i Motherboard Problems...
Forum Motherboards & Memory : General Motherboard - Evga 780i Motherboard Problems...
If anyone could help me with this, I'd appreciate it..
I got 2 9800 Gtx graphics cards a few weeks ago, and at the time, I was using a XFX 680i mobo with a Q6600 cpu. I decided to upgrade to a Evga 780i mobo, to take advantage of the PCI-E 2.0 SLI slots for my 9800s. Installation went fine, but when I went to overclock like my past system was, I ran into some big problems. I've been running my Q6600 at 3.0ghz just fine in my past XFX 680i SLI LT mobo, but now, if I overclock the cpu past 2.7ghz, it refuses to boot. It just sits there with the fans blowing at 100% and never displays POST or anything. I have to manually jumper the bios to get it to start again. I even tried flashing the bios to the latest p07 and it doesn't want to flash at all.
I've heard tales that the 7 series doesn't like overclocking (and people getting bad motherboards), so I guess my question is (since i just bought this thing) is this normal for this board, or should I ship this back for another one....
Thanks for any assistance....
Sponsored Links
You did set your memory multiplier so you are not overclocking it?
And I personally would not have changed my motherboard if I had a stable 3ghz overclock already running on another board. THe PCIe 2.0 slots won't make a big difference, at all.
Also, you might go here and see if someone can help.
http://www.evga.com/forums/tm.asp? [...] y=&#222688
Message edited by jitpublisher on 11-22-2008 at 08:10:16 PM
Reply to jitpublisher
the problem you had is the same as the one i had, what i found to be the solution was reinstalling windows and setting the dimm reference voltage to 50% of the dimm voltage manually, i am running the msi 780i and for a long time the only way i could start the system was in standard clock mode and then enter the bios and boot up my saved settings but now i boot up everytime on these settings with a q6600
vid 1.3 +.175 (1.475)
dim volt 2.2 (memory)
dimm ref volt to 50% of dimm
cpu gtl ref 65% of vtt(fsb)
nb ref volt 68% ovf vtt
vtt 1.252 volts
THE DIM REF VOLTAGE IS THE KEY IF YOU ASK ME
Reply to Anonymous
SORRY MY FSB WAS AT 378X9 AND WAS LINKED TO RAM DDR2 756@5-5-5-17 2T
Reply to Anonymous
There are 522 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
