Case - Antec 900 http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
(although im somewhat considering the Antec 1200 since its a little bigger, and has removable/washable filters)
Power Supply Antec TPQ-850 850W ATX12V / EPS12V Power Supply 100
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371009
Memory - G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory - Retail (I would be getting two of these so it would be 8gs 4x2gb)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145
Motherboard - ASUS P5Q LGA 775 Intel P45 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131295
(I really dont know much about this motherboard, I was originally looking at the x38/x48 but they seemed significantly more and I dont plan on doing extreme overclocking)
cpu cooler - Tuniq Tower 120 Universal CPU Cooler 120mm LED Cooling Fan and Fan Controler/Heatsink - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835154002
cpu - Q9550 (with the recent price drops and taking the place of the old q9450. Also I was curious if getting the new non extreme Q9650 would be worth the extra 150-200)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115041&Tpk=q9550
Hard Drive - Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148288
(although I heard that the western digital was generally better, I just noticed that this one was roughly the same price/speed as the western digital equivalent but had a 32mb cache instead of 16. Then again I dont know hard drives well)
I obv would use vista 64 bit premium since im going with 8g of ram, and for the gpu either a 4870x2 or a single gtx 280. (im waiting for the prices/benchies on the 4870x2 before deciding)
Any input/advice would be immensely appreciated, and im just curious if theres anything else specical id need to buy for this build. Only other thing I think I need for this would be some thermal compound ?
Also how difficult of a build would this be for someone who never built a pc before ? (I dont mind having to take it apart and redo it, but im just somewhat worried about how easily I could damage/destory the hardware.)
