Alright, I could use some Pro Help here so if you are great with cooling, keep reading
I've added an aftermarket cooler to my card, reducing the temperature at stock clocks from 90c+ on load to 70c+. Now after some heavy overclocking, I seem to have the same problem again. I'm back to 90c+ temperatures. I'm really looking into some solutions that don't include water cooling or some really heavy mods. Airflow inside the case is great although a pci blower just might help a tiny bit.
Now the heatsinks that came with it are rubbish, so i'm looking to purchase some forged copper heatsinks from either enzotech or swiftech. My Problem is here. Due to the nature of the cooler, some of the forged heatsinks would have to be bent in order to fit. How would I go about doing this without damaging the heatsink. Here is an example.
Secondly, is there any place that i can place additional heatsinks to the back of the card without shorting it out? I have heard that some more heatsinks in the right spots will cool even further.
You get a pair of small pliers and you bend them. Can't be too hard. It's just copper.
I wouldn't put any on the back. Can't put any on the GPU area, and the circuit card material is an insulator.
But you do what you need to, so just do it. I happened to get a Thermalright cooler for my GPU before I went water. It was top rated. It is awesome. It had reviews.
You spent $55 on a cooler for a $100 video card.....now you want to spend more.....I dont get it.
If you had bought the 4850 that blows air out the back, you wouldnt have this problem.
Mine has copper heatpipes and blows air out the back and never goes over 55c under load and its factory overclocked.
For starters, the card was not cheap a year and a half ago when I had bought it and I didn't see any gpu cooler tests on that cooler. In addition to this, they didn't make the 4850s dual slot blowing out the back when I bought it.
Factory overclocks suck, you can get more out of it doing it manualy. Surely someone has some decent input with regards to the heatsinks.
Hmm, I wouldn't of bought the cooler without having some solid reviews.
Anyway, best of luck in the extra heatsinks, get mo' air on that card, increase case airflow and add a fan somehow to blow across it. Not much more you can do.
The cooler does seem be lacking and direct airflow should help the cooler cope with lack of surface area.
Putting heatsinks on the back of the card should help draw more heat away from the GPU but I have heard that some of metal spots on the card will short if other metal is touched to them. However, some spots close to the GPU are safe.
The pictures of the bent heatsinks only show the bent heatsinks, not how to bend them. Its forged copper, one can't just bend them with their fingers.
Ahh ya win some, you lose some.
Message edited by Conumdrum on 10-08-2009 at 03:42:03 AM
Sure they did. Thats when I bought mine. So how much you got into this card already? $200-$250? Cut your losses and just buy a card with good cooling to begin with. Oh and factory overclocks dont suck, because when you buy one, you get one with a good cooler like this one and you can overclock more:
Don't talk about things that you have no knowledge about. The card was well over 150 when i bought it. I also bought it when those cards came out, most had just about the same cooler. How nice to have a good cooler on the same card, several months later, even a year. Imagine that. I have 4 friends with "factory overclocks" and they have even done some tweaking themselves, and i've beaten them all in comparable or even arguably better cards.
All I was asking was about the heatsinks, but since only Conumdrum provided some kind of useable feedback, I guess Toms forums doesn't know much about modding. I'll go elsewhere
Thanks anyway
