Tom's Hardware > Forum > Motherboards & Memory > Memory > Why my RAM not running at 1066...NEED HELP!!!!
Forum Motherboards & Memory : Memory - Why my RAM not running at 1066...NEED HELP!!!!
I have installed 2 GB(1x1GB) of OCZ RAM (PC8500) on a ASUS M3A79-T Deluxe with an AMD 9950 125 watt B.E. and i am getting this on CPU-Z...
DRAM Frequency-334.5 MHz.
(CL)---------------- 5 clocks
(tRAC)-------------5 clocks
(tRP)---------------5 clocks
(tRAS)-------------15 Clocks
(tRC)--------------19 clocks
(CR)---------------2T
Slot # 1 DDR2
Max bandwith-PC2-5300 (333 mhz)
TIMINGS TABLE
Frequency---------270 270 333 533
CAS# Latency----3.0 4.0 5.0 5.0
RAS# to CAS#----4 4 5 5
RAS# Precharge--4 4 5 5
tRAS-----------------13 13 15 15
tRC------------------15 15 19 22
Command Rate--- 2T
Voltage------------ 1.8 1.8 1.8 2.100
Same thing with the second slot
I REAllly do not know how to clock this back up to 1066 (noob...i know) Can some one please tell me how to clock this using Bios? It would be helpful if i can get step by step.
Message edited by Cartuner401 on 11-25-2008 at 02:05:50 AM
Sponsored Links
There are 588 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
