Well this is my first ever computer build, and after assembling it all, it will not POST, absolutely nothing appears on the monitor.
Here are my components:
Motherboard: MSI K9A2 Platinum
CPU: AMD Phenom 9950 Black Edition
Memory: Mushkin DDR2 800 2x1GB
HD: Western Digital Caviar SE16 500GB SATA
Video: Sapphire Radeon HD 4850
PSU: Xclio Greatpower 600w
Disk Drive: Lite-On SATA dvd burner
If youd like to know any other specifics, just ask.
But anyway. Everything is assembled, all connections checked and double checked. When I turn the power supply on, an amber light turn on on the MB, then when I press the power switch, the cpu fan and video fan both come on at full speed. I can feel the hard drive vibrating slightly when I put my hand on it, and I am able to eject the disk drive. Once I turn it on, a white and a green LED come on on the MB, and the video card begins a continuous cycle of a higher fan speed, which decreases was two LED's come on on the card itself, and back to the higher fan speed, spending a bit more then a second on each. CPU fan speed is constant. I cannot tell what BIOS version is currently installed on my board, the actual printing on the board says "MS-7376 VER:1.0" but then I found a sticker that says AMIBOIS VV15. I have tried clearing the CMOS, didnt help. I am using an old CRT display with a supplied DVI to VGD adapter that came with the video card as I have not ordered my monitor yet(will be a LCD). No beeps from the speaker, and I have not been able to find any reference online to the different colored LED'd on the board.
If you have any ideas, please post them, anything would help.
If anything else develops, I will be sure to leave an update
