Can;t decide on a case. Help?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Can;t decide on a case. Help?
http://www.newegg.com/Product/Prod [...] 6811119068
http://www.newegg.com/Product/Prod [...] 6811119137
http://www.newegg.com/Product/Prod [...] 6811129021
http://www.newegg.com/Product/Prod [...] 6811133154
http://www.newegg.com/Product/Prod [...] 6811146047
a bunch of cases and I can't decide, so you be the judge. Take into account quality, price, and ventilation.
also, if there is a better case, but not much defference in price, do mention it
Message edited by ipoopfool on 10-22-2008 at 04:12:52 AM
Sponsored Links
Antec 1200? Its a little more, but definately a nice case.
Message edited by the last resort on 10-22-2008 at 04:19:22 AM
Reply to the last resort
Check out the Coolermaster HAF 932. One of the nicest cases I've seen in a while.
http://www.newegg.com/Product/Prod [...] 6811119160
Also check out the Tagan Diablo, also very nice.
http://www.newegg.com/Product/Prod [...] n%20diablo
------------------------------ ASRock X58 Extreme - Core i7 920 - 6GB Crucial Ballistix DDR3 1600 - Sapphire 4890 2GB - Creative Xtreme Gamer - 4-80GB WD in RAID0 on HighPoint RR 2310 as OS drive - 1-320GB WD scratch drive - Corsair CMPSU 750TX - HAF 932 - Hanns-G 281DPB @ 1900x1200
Reply to chunkymonster
I took a look at the cases you are interested in. There is a price range from $50 to $150. I also noticed that you are interested in mid-tower cases and full tower cases.
Is $150 your upper limit?
Are you a gamer?
Are you going to be moving the case from time to time?
Do you need space for a large cpu heatsink and/or a large video card?
Reply to JohnnyLucky
Umm, yea lemme check.
Im gonna need an atx mobo with 1 hard drive and one dvd/ cd burner thingy. a 4850 or 9800 gtx+
I am kinda a gamer, and no I probably will not be moving it too much
Im not sure bout the size of the cpu fan or video card
Reply to ipoopfool
Your components make this fairly easy. You don't have a mile long list of components and peripherals. You'll be fine with a mid-tower case. The CoolerMaster 690 and the Antec 900 you listed in your original post will both work for you. Both of them are very good cases. All you have to do is decide which one you prefer.
Good Luck!
Antec 300 $60 with free shipping (shipping runs me about $20 for a case)
good cooling, cheap.
http://www.newegg.com/Product/Prod [...] 6811129042
Reply to dirtmountain
Ref: johnnyLuck
Recently bought the CoolerMaster 690. Not a lover of this case, although it may be OK for ipoopfool'sl current configuration. Well Built, but not the best design
If under a desk the front panel connectors (USB/firewire/esata) are located on top making it hard to use (Had to cut a notch out of under-the-desk self.
Fans on top are a nonstandard 15 mm (vs 25 mm) size. Also if you have a rear facing HSF and a rear exhaust fan the top fan will be ounterproductive to the air flow across the Processor heaf sink.
If you use a larger size PSU (I have an Antex 850), you cannot mount a intake fan at the bottom. I have a fan there, but it just sits there - no screws. FINE for standard sized PSU.
The front intake fan is very weak and the HDD cage blocks/restrict the air flow. In fact I replaced the two supplied fans (Added cost).
Dumb! I had read the Newegg reviews - should have known better!
Message edited by RetiredChief on 10-24-2008 at 05:31:52 PM
Reply to RetiredChief
RetiredChief,
Well now, your post is a perfect example of personal preferences. Everybody has their own specific requirements, personal preferences, and opinions. Luckily there are hundreds of cases to choose from. There's something for everyone.
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Can;t decide on a case. Help?
There are 959 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
