Hey all... I had an extremely stable o/c with my system...just added 2 more gigs of same ram.
Accidently hit some buttons in bios...lost all o/c settings. Any help to get my system back to 3.4ghz with ddr2 running at 850 any help with my bios settings would be greatly appreciated.
BTW... YOUNGSTER? I've been here for years and have never been so insulted. Perhap's I should stop referring my friends to Tom's and towards a more polite troubleshooting website.
Message edited by Pintail on 10-09-2009 at 12:05:43 AM
Try the above first. If your OC is stable dont change the settings below.
FSB over voltage control...+.1
(G)MCH over volt control...+.1 or +.2
Will try again...but I'm pretty sure my first O/C did not involve messing with the voltage settings. Perhaps adding the 2 more sticks of ram will require this?
-I have looked for my paperwork with all of my o/c settings written down, cannot find it.
-I have researched my prior posts, favorites, and links before posting.(some lead to stickies here)
Thank you for the courteous answer, unlike others who reply with rude and insulting commentary.
------------------------------e6750(stock cooling)@ 3.4GHz(425Mhz bus)|GA-P35-DS3L|4x1gb Patriot Extreme Perfomance DDR2-800(6400LLK)@850MHz 4-4-4-12 Dual Channel|BFG 8800 GT OC2|WD Caviar 16/500mb|LG GSA-4167B DVD Burner|Corsair HX-520|Viewsonic E70 17" CRT|Coolermaster CM 690
Reply to Pintail
