Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Help with monitor upgrade!!
Forum Graphic & Displays : Graphics Cards - Help with monitor upgrade!!
Hi I have a Belinea 10 20 35 W 20.1" monitor which was awesome for the price when i bought it. However I am upgrading my GFX card to a GTX 280 and would like a monitor that would really do this card justice,
The belinea is fine but the blacks are not that black and there is light leakage in the corners the response time is 8ms.
I am looking for a monitor that is around 22". Not too expensive around £300 or under. that will do my GTX 280 justice!
I would prefer a monitor without speakers so that it also looks the part. I like the look of the dell ultrasharp monitors, are they any good? would they be much better than my belinea?
Is it the contrast ratio that determines how black is black?
Although maybe my belinea 10 20 35W is a good display still these days? im not sure.
Here are the specs:
Belinea 10 20 35W
Hardware Specifications:
Display Type: Active Matrix TFT
Dimensions (mm): 474 x 218 x 433 (W x D x H)
Colour: Black and silver
Weight: 6.4kg
Connections: DVI-D, D-SUB, audio in
Viewable screen size: 20.1in
Maximum resolution: 1,680 x 1,050
Contrast ratio: 800:1
Response time: 8ms
Extras: Non-captive D-SUB cable, audio cable, 2 x 2W speakers
Sponsored Links
There are 1056 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
