Using a CPU Stress test app hitting both CPU's at 100% for little over 5min now - SpeedFan is saying
I have a cool master water cooler thinking about get http://www.newegg.com/Product/Product.aspx?Item=N82E16835118223
Temp 1 - 63c
Temp 2 - 44c
Temp 3 - 67c
CPU - 64c
Internal Temp - 40c
Remote temp - 64c
Temp 1 - 40c
Core - 63c
Both 80mm fans are at 100%
2344rpm & 5075rpm
9min in
Temp 1 - 66c up from 63
Temp 2 - 44c same
Temp 3 - 70c up from 67
CPU - 64c - same
Internal Temp - 40c - same
Remote temp - 64c - same
Temp 1 - 40c - same
Core - 63c - between 67 and 70
35min in
Temp 1 - 71c
Temp 2 - 46c
Temp 3 - 72c
CPU - 64c - same
Internal Temp - 41c
Temp 1 - 40c - same
Core - 73c
About 45min in
Temp 1 - 74c
Temp 2 - 46c
Temp 3 - 74c
CPU - 64c - same
Internal Temp - 41c
Temp 1 - 40c - same
Core - 75c
Going to keep this going for awhile im thinking of switching from water cooling to fan and heatsink and adding a 120mm fan but trying to see if my system is really getting hot or not.
Also i find it odd that both fans are the same and one only goes to less than half the other one does *shrug*
Time of this report: 10/24/2008, 01:54:42
Machine name: COCKPINK
Operating System: Windows Vista™ Ultimate (6.0, Build 6001) Service Pack 1 (6001.vistasp1_gdr.080917-1612)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4600+ (2 CPUs), ~2.4GHz
Memory: 3326MB RAM
Page File: 2935MB used, 3917MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 10
DX Setup Parameters: Not found
DxDiag Version: 6.00.6001.18000 32bit Unicode
Card name: NVIDIA GeForce 8800 GTS 512
Manufacturer: NVIDIA
Chip type: GeForce 8800 GTS 512
__________________
Temp 1 - 63c
Temp 2 - 44c
Temp 3 - 67c
CPU - 64c
Internal Temp - 40c
Remote temp - 64c
Temp 1 - 40c
Core - 63c
2344rpm & 5075rpm
9min in
Temp 2 - 44c same
CPU - 64c - same
Temp 1 - 40c - same
35min in
Temp 1 - 71c
Temp 2 - 46c
Temp 3 - 72c
CPU - 64c - same
Internal Temp - 41c
Temp 1 - 40c - same
Core - 73c
About 45min in
Temp 1 - 74c
Temp 2 - 46c
Temp 3 - 74c
CPU - 64c - same
Internal Temp - 41c
Temp 1 - 40c - same
Core - 75c
Memory: 3326MB RAM
__________________
