hi!everyone
my Sound Blaster X-Fi XtremeGamer Fatal1ty Pro Series can't fit into my armor va8000b full tower case. please help me. i already call Creative customer service,they do not sell the metal bar of the sound card. my friend told me i should modify my pc case but i do know how. anyone know where i can buy a universal metal bar(if there is one on the market) for sound card,plz let me know. thank you in advance.
What do you think is stoping your sound card from fitting in your case?
As long as your motherboard is mounted in the propper orientation, there should be no issues.
Try removing the plastic tool-less retention clips and see if it fits then.
------------------------------If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Reply to outlw6669
i like to hear or see a pic of this. a sound card not fitting in a full tower case. i never seen the x-fi before but i doubt its a big or long card right?
I have the same sound card as you and I really can't see how it would not fit .... especially with a full tower ! Like others have said it would be nice to see some pics.
Message edited by smartel7070 on 10-24-2008 at 05:52:22 PM
How could a sound card not possibly fit in that huge thing? The metal bars in the armor series are right below the PSU so it can't possibly be blocking any of the pci or pci-e slots.
------------------------------Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
thanks for everybody for quick responses. i tried again this morning and got my sound card 95% fit into the slot . but here comes another question, does it has to be 100% into slot on the motherboard? thanks
i might wanna re-install my motherboard and try. i am kinda confused too that my soundcard doesn't fit into a full tower case.thank you again
How does it not fit?! You are saying that it doesn't go into the slot all the way... Did you install the stand-offs before installing your motherboard. Pictures certainly would help.
------------------------------E8600, Rampage Formula, aXeRam DDR2 1200, GTX260/216
Reply to erocker
YES it has to be all the way in. Pretty much always when it's not all the way in, you're in short-city.
+1 to "we need pics" how would you not be able to fit anything into a full tower case? A full tower should have no problem fitting 2 HD4870x2's!
------------------------------E8400 3.6Ghz | 4GB DDR2-800 | HD4870 | 780GB HDD Space | VX550W | WinXP | Win7-64 | Ubuntu Studio 8.10
Reply to doomsdaydave11
