Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Asus > Problem with Asus Striker II NSE, freezing
Forum Motherboards & Memory : Asus Problem with Asus Striker II NSE, freezing
My pcŁ
PSU: 1000watts
GPU: Evga GTX 280
MOBO: Asus Striker II NSE
Ram: OCZ 4gb 1333mhz
Cpu: Quad 2,8ghz
Everytime i play a game or 3d application, my computer suddenly locks up/freezes/crashes. . The audio/sound loops over and over fast. There's nothing i can do including ALT CRT DEL, or switch to desktop or QUIT. The computer totally freezes.
It first started on Bioshock my first game on here, but it only happened every like 1hr or so. Now it has become frustrating more with me playing bioshock and it happening every 5 - 30mins. Its got damn annoying. Other games freezing: CRYSIS, CALL OF DUTY 4 , Brothers in arms : HELLS HIGHWAY , and others...
updated BIOS, GRAPHIC CARD, and MOTHERBOARD and AUDIO.
I just read on other forums that problem is in chipset 790i. Some peoples have this freezing on other mainboards on 790i.For example : Evga 790i, Asus Extreme
Other peoples say that my memory ( OCZ ) is not good for my mainboard.
When i tested PRIME95 is ok for a many hours . SuperPi too... Memory i have 1,8 voltage , so its ok. Others voltages i have on default. So whats is problem ?
Just enter on google something like that in my problem . And you see ....
http://www.ocztechnologyforum.com/ [...] p?p=282175
http://answers.yahoo.com/question/ [...] 920AAWQpZz
http://forums.nvidia.com/lofiversi [...] 66042.html
Reply to Anonymous
Sounds like your running a Q9550 @ stock 2.83GHZ and 4GB of ram. Is that 4 X 1GB or 2 X 2GB of ram?
I have a Q9550 @ 3.83 C1 prime stable for 6+ hours.
Asus Striker 11 Extreme BIOS 1104
OCZ ram 2 X 2GB PC 2000
2 X 8800GTX 512 BFG GPUs OC'd.
PC Power and Cooling 750W PSU
Probably the most important thing with these M/BDs is when using OCZ memory (and perhaps all memory} you have to set the timings manually per mfg specs as well as the rated Vdim for that particular memory. They also seem to like 2 X 2GB of ram better than 4 X 1GB of ram.
I am very happy with how my PC runs.
Reply to arthurh
- 0 +
sew333,
you need to set the timings and voltages on that memory in order to get it to run stable. do not leave it on default timings and voltages.
Reply to chinh_n
- 0 +
I got this MoBo with OCZ as well and it crashed on me at completely random times... I narrowed it down to the ram and went to corsair. I threw down quite a bit for a some quality ram that they claimed to be compadible with the motherboard... Sure enough it runs absolutly perfect now.
CORSAIR XMS3 DHX 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Reply to Yinten
Yes, but i would like to know what Bios Settings you have??????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????Please!!!!!!!!!
Reply to Anonymous
- 0 +
well i have this mobo + same processor and i can tell you that you have not changed all the settings to your stock ones and if you do it to all of them (btw i did and it was a f*ck load of research) it will run properly. In my opinion it is your ram but i know that **** runs on your mobo your just not setting up the stick right
Reply to kcmark
- 0 +
What cured my problems with my board was setting the NB voltage to 1.42v, now I have no problem running at 3.2GHz with a FBS of 1600 CPU & memory, I'm also using Bios 1202.
Message edited by baddad on 01-07-2009 at 03:49:56 PM
------------------------------ ASUS Sabertooth X79, i7- 3930K 4.55GHz, 32GB of Corsair Vengeance DDR3, 2 EVGA GTX 580's SLI, Thermaltake 1000W PSU, Thermaltake Xaser VI Case, Acer 27" 120Hz, Water cooled, W7 64 bit Pro http://www.youtube.com/user/BadDadOne
Reply to baddad
any solution yet?
i have the same rig as you,
but mines Corsair XMS3 4GB x 1GB
------------------------------ Asus Striker II NSE, Intel Core2Quad Q9550 2.83.Ghz, XFX Nvidia GTX 280, Corsair XMS3 (4 x 1GB), ToughPower 850w, Vista Ultimate 64bit
Reply to liquidignition
There are 1538 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Memory for GIGABYTE GA-G41MT-S2P
By fantastik250, 11 hours ago:
Take a look at this and see if you like it. http://www.newegg.com/Product/Prod [...]...
Best offers
Top experts
