Ok i have a GA-EP35c-Dsr3, And i have just bought 8gb of kingston 1066 Ram As i notice on the mobo box it can handle that and even overclock to higher speeds etc.
Now i havnt overclocked my processor which is a E4600 Dualcore.
Now atm when i turn my pc on it stats this is cpu that my rams SPD = kingston pc2-6400 (400MHZ) When its not its 4 sticks of kingston pc2-8500 ram so how i fix anyone?
Also my cpu is running 1.32500V 200 (fsb) and mutiplier X12, now i notice if i click my fsb to 250 making it 3.00GHz on , the ram bios rea shows the ram @ 1000 nd with a sector called memory mutiplier and shows (800 or 1066 strapping) which i have no clue is and how i overclock the memory for a more performing pC. I have atm only got the cpu with stock hsf tho i read up that my cpu is easy to overclock i just need tooverclock the fsb from 200 to 250 and the reveiw stats is ok on auto voltages settings and the cpu standard hsf actuly keeps it stable. this will then get the ram to 1000 but its still not running @ its speed and when i purchased in the first place it was because the memory was old and updated for faster ram and the box said 1066 ,(1200 O.C). so i was expecting good spedds whatim i doing wroung?, as i cant even figure this useless easytune program out that seems to only run when it wants /remove, ok nvm that program how to fix anyone else no how or having same problems?
