Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > PC Power & Cooling 750 Watt Cable Length
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - PC Power & Cooling 750 Watt Cable Length
Anyone buy a PC Power & Cooling 750 watt PSU lately? Any observations on the cable lengths? One of the criticisms I've seen of their PSUs is that the cables may be too short for mounting at the bottom of the case.
Checking out their website it looks like they've recently added several inches to the CPU (8 pin) power cable. The harness diagram was updated 9/20 (no year mentioned) and the length shown is 23", longer than what's mentioned in reviews.
Sponsored Links
Hehe. You're in luck. My TX750 was delivered a couple hours ago. I just opened the box and measured the 8 pin power cable. It's 24". Going to make it much easier for me with my p180b case.
Reply to orangegator
- 0 +
I don't know about "lately" but my Silencer 750W bought 15 months ago works fine at the bottom of a huge Silverstone TJ-09. I didn't need any cable extensions.
Reply to aevm
My PC Power and Cooling 750w that I had fit perfectly well in my Silverstone TJ07, which is slightly taller than aevm's TJ09, although it BARELY fit around my 4870 X2. The cable length is perfectly fine, except the 8 pin might need an extension if you want an extremely clean looking case, otherwise it will work in any case I can think of, since very few are taller than the TJ07 and those usually don't have a poor PSU mounting system like the TJ07...
Reply to The_Blood_Raven
ye, fits fine at the bottom of my antec, only one that came close to bening too short was the cpu power cable.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to Strangestranger
There were previous threads here at THG and user comments at vendor web sites about short cables. The problem is the 6 pin, 2x3, ATX power cable. Some people reported problems with full size tower cases where the psu was mounted at the bottom of the case and the motherboard connection was located at the very top. Video cards and other components sometimes get in the way. With good cable management the power cable is run up behind the motherboard tray. If the cable is short, the easy solution is to purchase an 8 inch extension cable which is available at vendor web sites.
Reply to JohnnyLucky
There are 1177 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
