I have decided to hold off on the high end system until Nehalem becomes affordable about this time next year, so I am going to build a system in the mean time that will be utilizing my 19" Viewsonic LCD at 1280x1024 resolution. I will continue to use the 32-bit XP Pro as my OS.
My question is what kind of set up would be sufficient to max out every game at 1280x1024 on a 32-bit XP Pro platform? Really just a part time gamer that usually plays MMO type games (Warhammer Online, etc) and occasionally CS:S or UT. Just looking for a system that allows me to play these games smoothly at the resolution I stated above.
Here is what I think I could get away with to achieve this and get the best bang for the buck at the same time:
Video Card - ATI 3850
HD - 250 meg WD 7200 RPM sata
CPU - E7200 or E8400 Core 2 Duo
RAM - 2 GB DDR2 800 or 1066
MOBO - mid to low $ range P35 or P45
CPU Cooler - Artic Freezer Cooler 7
I will OC the CPU and GPU but not to extremes.
Appreciate any insight or advice!
