Im looking to overclock my PC, using water cooling.
The company "www.digitalstormonline.com" say that you can use just two 120 rads to cool a cpu and up to two graphics cards.
Is this really right?
Ill be using a CM Scout, i5 and two 4870s
air cooled hd4870's get very hot i know i have 2 and they require my fans speeds set to 50% or they crash in game , although i have more heat generated in my case than the average user.
^Depends on if you get the reference cooler or not. I know Sapphire's VaporX works quite well. Not sure if it'll be able to do CrossFire (depending on board/case) as VaporX is a dual slot solution.
Message edited by shadow703793 on 10-14-2009 at 10:49:28 PM
i got 1 with a ref cooler which is the worst and the other is similar to the vapourx design and they both overheat tbh but the stock one is louder to achieve the same temps
^Really? Many of me friends are using the VaporX 4850s and they (AFAIK) haven't/aren't overheating. I guess case airflow and ambient play a big part also eh?
i don't even have the vaporx design, just the sapphire heat pipe design and it never even comes close to over heating, then again i have a 120mm fan blowing right on it
The sapphire 4870x2 atomic manages to squeeze two RV770s and a CPU block into one 120mm Rad!
GPUs get to 54 degrees under load, CPU at 48 degrees idle.
Thats pretty impressive for a single 120 I think!
Impressive for a 120 rad to cool both. Good temps? Nope.
You mean a 4870x2. Not some arcane chip name. It's a 4870x2.
Hmm no metion of ambient temps or what it was installed in/on. I can pretty much bet it wasn't inside of a case.
So the test has very little validation, usually expected and written into a review. Actually, reviews isn't where we find out best data, it's tests done with consistent scientific methods, like here.
http://www.skinneelabs.com/ Science at work.
