Working on a first time computer build. q9450 quad core, Vista 64 bit system. I plan to install minimum 4 GB DDR2 ram (2X2GB). However, I thought I read somewhere to start by installing only 1x2GB memory module first (channel A1), then install/setup Vista. Later, add the 2nd 1x2GB module in (channel B1). (Maybe this applies to Vista only.)
Any thoughts? What is the correct path for a new computer build?
Should I just install the entire 4GB from the beginning?
How about 8GB? Can I upgrade later to 8GB? or is it better to install the entire 8GB from the beginning?
Thanks!
Thanks!
