I want to unlock a X3 720, and do some light OCing. If my stock AMD heatsink/fan are not fit for the task, which low $ setup is best? (or something else!).
Scythe SCKTN-3000 92mm Sleeve "KATANA3" 3Heat Pipes CPU Cooler - Retail $28.69
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185096
ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU Cooler - Retail $33.98
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
I am concerned about the AC fitting on the 770T UD3P board w/ GSkill Ripjaws DDR3 1333. Saw some reviews about the unit hitting the ram. Not sure of the size of the Katana3.
Any advice/opinions/etc ???
Thanks in advance!
Thanks in advance!
