News
Leak: ATI Radeon 4800 Gets 480 Stream Procs
AMD/ATI is set to release the (RV770) 4800-series of graphics cards, including the models 4850, 4870 and 4870 X2. While the launch is still very much a secret, we were able to receive details and the specifications of the new cards. Read more
Nvidia GeForce GTX 200 Prices Crashing
Pricewatch - There is trouble in Nvidialand. Read more
Gateway Debuts New PCs Designed for Gaming and Digital Media
Gateway announced two new desktop PCs today, the gaming-oriented FX6710 and the LX6200, which the company says was designed with “digital media enthusiasts” in mind. Read more
ATI Runs PhysX With Modified Drivers
Haifa (Israel) - This one did not take long: We already knew that Nvidia is working on a CUDA version for x86 CPUs, but said it would leave a modification for ATI GPUs to others. Read more
Latest Reviews & Articles
1.5 TB Low-Power HDDs: Green Gets Big
The latest 2 TB hard drives are still expensive, but 1.5 TB disks provide low power consumption at a better cost-to-capacity ratio. We look at offerings from Samsung and Western Digital to determine the value of taking a step down from the flagships. Read more
ADVERTORIAL Microsoft's BPOS: Q&A for Skeptics
When a new paradigm like cloud computing or a new platform like Microsoft’s Business Productivity Online Suite (BPOS) comes along, it’s smart to ask tough questions. Read more
MSI Eclipse Plus: Does nForce 200 Boost 3-Way SLI?
With 36 lanes of PCIe 2.0, 3-way SLI could be the X58 chipset’s biggest challenge. If that turns out to be true, is Nvidia’s nForce 200 controller hub, which multiplexes the platform's connectivity, a solution? We compare three configurations to find out. Read more
Gigabit Ethernet: Dude, Where's My Bandwidth?
Once we make the jump to Gigabit Ethernet, the expected tenfold increase in network speed doesn't seem to materialize. We'll look at the basics of gigabit networks, what limits their performance, and how we can get the best possible speed out of them. Read more
All the Reviews & Articles
4870 fps problem
hello i writing to ask for some advice i think i have got a faulty 4870 because i keep get low fps i was on tf2 and i have seen 16 fps that cant be right does any or has any had this problem
Sponsored Links
Ok thing is i got a new pc the following specs are : intel q6600 radeon 4870 2 gb of kingston ram 800 w psu asus p5q e mobo and windows xp 32bit. the question iam asking is i play alot of games and on tf2 my minimum fps is 16 which is low i have seen people with the same even worse hardware getting higher than that and also on crysis with all the settings on high not very high because for some reason wont let me put it on v high and i still get minimum of 7 maximum of 38 and thats standing still with no action is there something i have put wrong i have the latest driver 8.8 so is there something bottle necked any advice would be nice lol here is a more detailed description
Reply to rosariobig9
Something ain't right cause I run TF2 max settings with a q9450, 4gb ram, 4870 at the least 150fps. Make sure you have the catlyst control center settings set to use program defaults, I didn't before and it wouldn't let me set some of the settings in crysis to V high.
Reply to Shadow of Dawn
iam gonna sound like an idiot here but where is the program defaults
If your in the advanced view. There should be menues on the left side and one that says "overdrive" click on that one and then there's settings for AA, and other things like that. There should be a little check box on each of those for "application settings" just make sure you have them checked.
I'm don't have CCC on my comp right now but that should be how to do it if my memory is correct.
Because you have XP which uses DirectX 9.0c, Crysis can't run Very High spec because that requires DirectX 10 which requires Vista. The FPS for Crysis sounds about right, have you patched the game up? For TF2, something is up because your FPS should be going into the hundreds easily.
Reply to pcgamer12
did you try different servers at leasT? i mean i know when i play tf2, it can get slow to a crawl at times, but is smooth as butter at other times... could be an internet issue maybe? tf2 is an online game... i have a 2900xt btw
Reply to eklipz330
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 4870 fps problem
There are 846 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
