Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > Help on vid card pick!
Forum Graphics & Displays : Graphics Cards Help on vid card pick!
Hi everyone,
I am building a new computer and have purchased everything but my video card. I was hoping that someone could run through my specs really quick, and recommend a card that would run well with the other hardware I've bought. I've been stuck on this for a while now and I want to buy the perfect card. I was very close to buying Sapphires version of the Radeon HD 4870 when a guy at the office told me to never buy off brand manufacturers. He recommended to get the Ati version of the same card. I then pondered going the Crossfire or SLI route but my budget is around $350 and that can get more expensive.
Somebody please straiten me out! I want this machine to be fast and it has been 6 years since a built a system and I am very excited about this one. Here are my specs:
Mobo- ASUS Maximus II Formula LGA 775 Intel P45 ATX
CPU- Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core
RAM- mushkin XP ASCENT w/ eVCI technology 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel
PS- CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC
Hard drive- Seagate ST3640323AS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s
CPU fan- EROtherm Nirvana NV120 120mm 2-ball UFO Bearing / Transparent
Case- LIAN LI PC-65B Black Aluminum ATX Mid Tower
Graphics Card- ??
:wahoo:
Message edited by robdh0811 on 09-07-2008 at 10:05:03 PM
Reply to robdh0811
There should be nothing wrong on buying from Ati's manufacturers, they usually stick to the reference design given by Ati. The general consensus is that Sapphire is Ati's #1 partner, but that doesn't mean that the others are any bad, I bought a Sapphire card earlier this week and I'm hoping for it to arrive in the next few days.
If you for some reason don't want to buy a Sapphire branded product, then look for Visiontek, MSI, or Diamond.
------------------------------ Anxiously awaiting the Hydra 100 and the Hydra Engine...
www.lucidlogix.com
Reply to emp
Those are some nice specs but there is one very important one missing. What Monitor size/res are you using ?
Mactronix
Reply to mactronix
- 0 +
I forgot, given the fact that you already have a crossfire capable board, then maybe you could also take the 2x HD 4850 route for $340.
SAPPHIRE 100245L Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6814102770
www.lucidlogix.com
Reply to emp
Hey thanks for the prompt responses.
As far as a monitor goes, I think I am going to with a 1680 x 1050 res. I also wanted to inquire if it really makes a difference to get a monitor with HD or HDMI , in terms of fully displaying the graphics card's abilities.
http://www.newegg.com/Product/Prod [...] 6824001270
^^^ possible the monitor I would buy ^^^
EDIT: Also, why doesnt newegg or tigerdirect sell any cards manufactured by ATi?
Message edited by robdh0811 on 09-08-2008 at 01:36:15 AM
Reply to robdh0811
- 0 +
Not really, for a computer screen you will be using DVI instead of HDMI. DVI carries only digital video, while HDMI can carry digital video and audio, but since you will have speakers/headset on a computer for the audio, there's very little reason for a computer screen to have HDMI.
www.lucidlogix.com
Reply to emp
- 0 +
Crossfire performance on p45 is not ideal, due to pciex8 bottlenecking. Stick with single more powerful card instead.
http://www.tweaktown.com/articles/ [...] index.html
Performance benchmarks:
http://www.anandtech.com/video/sho [...] =3341&p=13
http://www.anandtech.com/video/sho [...] =3341&p=14
http://www.anandtech.com/video/sho [...] =3341&p=15
http://www.anandtech.com/video/sho [...] =3341&p=16
http://www.anandtech.com/video/sho [...] =3341&p=17
http://www.anandtech.com/video/sho [...] =3341&p=18
http://www.anandtech.com/video/sho [...] =3341&p=19
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
- 0 +
Look at the res he will be playing: 1680x1050.
So, CF at that res doesn't take ALL the bandwith from the X16/x16 and the 8x/8x holds on equally.
Now, that leaves no room for bigger res!
If you don't plan on going onto a bigger screen anytime soon (prolly before your next hardware change) keep the P45 and CF a couple of 4850's and have a blast IMO :P
Now, the single fastest card can also be a good choice, but not taken into consideration the "P45 not being capable", but a power/heat issue inside your rig.
Maybe a 4870/GTX260 is also a good choice and they'll last till you want to change your rig.
Esop!
EDIT: Spelling xP
Message edited by Yuka on 09-08-2008 at 01:55:42 AM
------------------------------ http://valid.canardpc.com/cache/banner/2001104.png
"If ATI's 2900XT was a loser, then nVidia's FX5900 was its retarded, sociopathic cousin." .- Random Comment-er
Reply to Yuka
There are 1527 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 5 hours ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
