performance on single thread apps should be the same to plain eye, however, multi thread apps will benifit from the extra threads.......and the power requirement will increase quite a bit
Message edited by sarwar_r87 on 10-28-2008 at 04:09:55 PM
I've seen that the TDP for all 3x i7 cpu's are 130W. So it just might use more power. because a 9550 has been rated at 95W TDP. But these TDP values should be taken with a grain of salt. If i,m not mistaken it just means that the max Watt the CPU could pull.
You've seen the TDP values. That's a dumb question to ask.
Not exactly a 'people' person, are you? Most responses you give take shots at everyone. The entire point of a forum is to ask and receive help...not to attack someone because they don't know the answer. If you are going to be that negative, just don't respond. Your inferiority complex doesn't need to take root in the forums, here.
------------------------------The Pastafarian belief of heaven stresses that it contains beer volcanoes and a stripper factory. Hell is oddly similar, except that the beer is stale, and the strippers have VD
Reply to rubix_1011
You're just a simple minded retard aren't you? Sure am glad I'm not you cause that must suck. Why don't you dump your pointless pathetic bleating on someone else. Definitely seek psychiatric help, you need it more than anyone.
Really? Wow...that ranks at about 3rd grade playground level. Impress me with something other than calling someone stupid or telling me I'm a retard. Pretty simplistic life you lead...'making fun' of other people. It's quite the irony that you tell me I need help, yet you are the narcissistic fool.
Message edited by rubix_1011 on 11-10-2008 at 07:56:26 PM
Reply to rubix_1011
Reply to rubix_1011
I dont see it as a stupid question... The 130w is a max TDP at which the CPU will start to throttle at (assuming Overvolt Protection is on) Considering all 3 i7's are at 130TDP you would also have to assume that the 920 and 940 will use less than the 965 due to their lower clock speed.
From reviews ive seen the 965 is around the same as the current EE Cpus from intel (QX9770) the 920 and 940 should be around the same as the current Q9300-9400 series.
Its also to be noted the the i7's will deliever MUCH better idle power usage than the current Quads due to the arch improvement and addition of the on-die power monitor. From what ive seen when idle they are extremely effecient.
------------------------------"This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
Actually, I am pretty sure the power consumption of your overall system..This is because although the TDP is higher intel has added some stuff into the cpu, the memory controller for example is now intergrated into the processor.
Either way the power supply you are using for your current rig will easily run a core i7 rig.
