Thanks for the fast replies, any other cards you would recommend?
Just need the greatest (and best value) card i can get that'll run on a 300W power supply and a 19A 12v rail
Well it depends on what you plan on doing with it.
As dagger mentioned the HD2600 series is another option.
But for gaming I would recommend waiting for the HD4650/4670 and seeing what it brings to the table for a card that doesn't require an additional power connector.
The HD4650 is supposed to be in the GF9500GT's performance area, and the 4670 well above it.
It's launching soon, and should give you the best performance options, but value is a relative thing and of course close to launch may or may not be a value consideration.
------------------------------You need a license to buy a gun, but they'll sell anyone a stamp (or internet account) - REDGREEN. GA to SK HD Freedom: 45 5F E1 04 22 CA 29 C4 93 3F 95 05 2B 79 2A B2
Reply to TheGreatGrapeApe
But if he's gaming it is worth the extra $30-40 though for the added boost.
It's all relative for sure, but for his setup without laying out more for a PSU etc, then the HD4650/70 are good options.
The HD2600 is still a pretty good value, but you will be more limited.
