HELP!
I have a home built computer which had problems for a while then died. It had an ASUS P5B-E MB, Kingston RAM, and a Core Duo procssesor. The funny issues it had up to death included not turnning on or failing to boot past the BIOS screen. I have a power supply tester and the PS tested good. I swapped the RAM for a pair of Crucial chips and that made no difference. I was able to turn it off for a while and it would turn on later or, sometimes if I unplugged it and then plugged it back in, it would function as normal until turned off again. Finally it just stoped turning on at all. No power supply or CPU fan activity. Tested PS and it still looks good (fan does turn on when tester is attached)
Is have purchase a new Gigabyte MB & power supply. I swapped those into the box, moving the old CPU and memory. Turned it on and again no fan activity (only the power leads attached and the CPU, RAM & heatsink in place).
I figured with the new MB, the problem must be the old CPU. So, I purchased a new CPU and replaced the old one. Still have the same issue.
Please tell me I am doing something stupid and do not need to purchase more parts. Not sure what to try next or how to determine which part is really bad or maybe if I received a DOA MB or CPU.
JDP
JDP
