Tom's Hardware > Forum > Overclocking > CPUs > Power and Heat: Overclocked 1156 Vs 1366
Forum Overclocking : CPUs - Power and Heat: Overclocked 1156 Vs 1366
I'm building a rig which would serve primarily as HTPC with occassional gaming and photoshop use.
I will be overclocking the CPU and narrowed down my choices to i5 750(1156) and i7 920(1366). Heat and low-load power consumption is important factor to consider.
Questions:
1. In terms of power consumption and heat: i5 overclocked by increasing the stock voltage = i7 920 overclocked at stock voltage??
If there is a difference, how big is that. I'm most concerned about the idle/low load power consumption.
2. Is it possible to overclock i5 750 with Turbo on?
Message edited by shaajahan on 10-21-2009 at 08:55:17 PM
Sponsored Links
1) not sure, I haven't heard of any huge differences.
2) yes but the resulting maximum clock may be lower than doing it the old way (turbo isn't ultra configurable, so when you change the base it may become unstable) and you should also remember 'turbo' only engages with single core applications and is only applied to a SINGLE core. Overclocking manually causes all four cores to run at the higher frequency (and results in a much faster result)
If you're going to overclock, don't bother with the turbo. It's brilliant for stock or mild overclocks on mainstream machines, but when you're overclocking it'll just get in the way once the speed gets higher.
For idle etc I just make sure I have Intel SpeedStep etc enabled, this auto underclocks your CPU when its not needed by dropping the multiplier. This is usually on by default.
------------------------------ Intel E8500 - 4.26Ghz - 533 x 8 - on air cooling with DDR2-1066 running native
Sapphire Ati HD4850
Reply to SpidersWeb
I have heard that the i5 750 requires less voltage than the i7 920 for higher overclocks and lower voltages mean lower temperatures.
I can't confirm since I do not own a 920 but these are my results.
I own a 750 running 3.8ghz with 1.26v 100% stable. Easily hit 4.2ghz on it, but load temps were approaching 70c so I just decided to keep it conservative for longer life. I'm using the cheap 212+ hyper heatsink also. (59c @100% load)
------------------------------ Q6600 @ 9x333, 500gb barracuda 7200.10
Gigabye DS3R P35, Evga 8800 gt
4x1gb Super Talent 800 3-3-4-8, OCZ 850w, Win 7 64
Reply to cory1234
There are 1136 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
