Tom's Hardware > Forum > Overclocking > CPUs > E5200 Water cooling
E5200 Water cooling
Forum Overclocking : CPUs - E5200 Water cooling
Hey,
I was just wondering what Kind of Speeds I should be able to get with a H50 on my e5200?
I was kind of hoping to get 4.5GHz but maybe that's a bit ambitious.
Any ideas on temps and voltages?
Thanks in advance.
Sponsored Links
Didn't you already make a thread with exactly the same question? Keep it to one.
PS: 4.5 GHz isn't going to happen unless you move to a cooling solution far more advanced than an H50.
------------------------------ AMD Phenom II X4 940 | Xigmatek HDT-S1283 | GIGABYTE GA-MA790X-UD4P | G.SKILL 2x2GB DDR2 1066 | XFX Radeon HD 4870 1GB | WD 500GB Caviar Black | Samsung 22X DVDRW | Corsair HX850W | Cooler Master HAF 932 | Logitech MX518 and G11
Reply to d0n7bl1nk
- 0 +
Just stop don't spend money on overclocking that get at least a q8200 if going water I have a q9400 at 3.8 with air just no need for water and no need for more than 4ghz you just won't notice anything above that.
T
Reply to thently
1. 4Ghz+ OC on the E5xxx and other Pentium Dual Core CPUs are hard with out high end WCing and high voltages.
2. The H50 is no better than a pretty good air cooler such as a Core Contact Freezer (~$20 right now at Newegg after MIR).
3. Full specs?
@Thently: I'd like to see you try 3.8Ghz with out WCing on a i7 + Turbo.
Quote :
False. It depends on the PROGRAMS you are running. Programs such as MAYA,etc you WILL notice a difference.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
http://www.egielda.com.pl/forum/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=1181
corsair h50 , 26'C in my room
Reply to Anonymous
There are 424 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
