Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > problem with new build
Forum Homebuilt Systems : General Homebuilt - problem with new build
hi guys i am having a problem with a new build of mine. i am getting freezes when i play some of the latest games which require that i restart my comp. in order to try and find out what was going wrong i ran crysis in windowed mode and had real temp and evaga temp monitoring program running in the back ground so i could see what the temps were when it crashed. the cores temp was in the mid 40s.(spread between 45 to 47) and the two gpus were in the low 60s. things are being run at stock. are these temps overly high?
graphics card is
EVGA 01G-P3-N892-AR GeForce 9800 GX2 Superclocked 1GB 512-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
and
cpu is
q9300
and temp in the room was about 75f
if anyone needs any more information just say so
Message edited by magoo2008 on 08-16-2008 at 11:01:20 PM
Sponsored Links
Hi magoo. What is the rest of your system specification? Motherboard,memory,power supply. Those temps aren't very high so it shouldn't be the cause of your freezes. How long do you play before it freezes?
Reply to cfvh600
There are 1114 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
