Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Which motherboard for Nvdia cards? Building new system
Forum Motherboards & Memory : General Motherboard - Which motherboard for Nvdia cards? Building new system
Hello
What would be a good non expensive board to get for use with the Nvdia gpu's and socket 775? I read alittle about the 790i and the X48 and X58.
What should I look for on a board?
Help please
Sponsored Links
First, any chipset will do if you use only one card (even dual-gpu cards like 4870X2 or 9800GX2). The 750i/780i/790i/X48/X58 cost more, but offer multi-card support (SLI for Nvidia and CrossFire (XFire) for ATI). For NVidia cards, you need an NVidia chipset (750i/780i/790i). For ATI cards, it's Intel chipset (X48/X58).
So, do you need SLI/Crossfire support?
Reply to Zenthar
Gigabyte GA-EP45-DS3L $105.00
Look for number of SATA ports, and accessories you need. P45 chipset is good unless you want to do SLI.
If you want SLI, get a EVGA 750i motherboard.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
- 0 +
Maybe SLI . So could someone recommend two particular boards please.
Reply to g335
What type of RAM? DDR2 or DDR3?
The 790i is the only board i know of that supports DDR3 and SLI (maybe ASUS has a board that does both?).
Reply to gamerk316
- 0 +
TRY GIGABYTE X58-DS4, THIS IS GOOD C/P
Reply to mooks
- 0 +
X58 chipset boards dont support socket 775!!!
Reply to peaks
There are 1359 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
