XFX 790i ultra p07 bios problem
Okay, so I've got a big problem since I bought this computer that I thought was going to be pretty awesome and still give me room to upgrade later but now won't do crap. Let me first tell you what i got then I'll explain the problem.
>xfx 790i ultra
>intel q6600
>Patriot PC3 10666 DDR3 (7-7-7-20 1333)
>Two xfx 8600gt XXX
Everything was running good. It would only freeze every once in a while. However, it would always freeze if I tried to benchmark. Nforce tools would never let me overclock or underclock. All this was before I tried to update the bios.
I figured updating would fix these problems. So i burnt a CD and updated to p07 basically from the original bios. Immediately after that when windows would get to the desktop it would freeze. It has freezed everytime since then. I have adjusted the voltages, no change. I even flashed back to the original bois. Still freezes.
XFX told me I should reload windows and see if that fixes the problem. But I hate to loose everything I got and also I can't just go spend 80 bucks on a new hard drive just to see if that's the problem. Someone please shine some light on this situation.
Anonymous
Motherboard Authority
I just Update my xfx 790i ultra sli with the po7 bios and everything is fine everything boot up fine... what xfx told you is to re-format your hard drive you dont have to buy a new hard drive...
if you are i recommend 300gb velociraptor...
XfX 790i Ultra Sli Motherboard
OCZ, 4GB (2 x 2GB) Platinum Edition PC3-16000 DDR3 2000MHz CL (9-9-9-28) 1.9V SDRAM DIMM
Ultra Products ULT-33186 ChillTec Thermo Electric CPU Cooler
Intel Core 2 Quad Q9550 Yorkfield 2.83GHz overclock to 3.8ghz
2x XFX 280 GTX XXX Edition
1100 Watts APEVIA WARLOCK POWER SUPPLY
300GB Western Digital VelociRaptor
Windows Xp SP3
Ask the community
