I went into BIOS upon installing (took the patriot memory out completely).
I set the SPD to 4-4-4-12-4. Gave it a shot and everything worked nicely. Slower boot but I figured thats because I had my CPU OC from 2.4 to 3.3 before with patriot. From what I can tell, the settings I have the RAM at are what is recc by Corsair.
Now, if I even try to take the CPU past 2.9 the machine is incredibly unstable. Didnt have any issues OC with the patriot. In fact, I even got the CPU to 3.6 but didnt like the temp so I kicked it back. CPU voltage is at 1.475 (Max is 1.5) and memory voltage is at 2.1. When I do OC I take it slow and try to maintain the RAM around 800MHz. With Patriot I was able to get it to around 900MHz, so a little OC but I took it back to 800.
Issues I have had:
-Sometimes the vista loading bar will just go on forever.
-Sometimes I get BSOD immediately upon entering windows. Last one was a BAD_POOL_HEADER error.
-Sometimes I get into windows and everything is just drastically slower.
Maybe I am just missing something? Please assist and thank you.
Message edited by Y2HBK on 12-03-2008 at 03:12:51 AM
Hmm, my initial reaction was bad RAM but the MEMTEST returned negative...you could always try one stick at a time just to double check your ram is good...Other than that, I don't know...not much into OCing
I use 2x2GB of G.Skill F2-6400CL4-2GBPK in mine at 5-5-5-15-Auto and 1.9V and its fast and stable. I tried them at 4-4-4-15 and the system was slow and unstable (less than 30 minutes before rebooting). The same modules had been working fine at 4-4-4-15 for several weeks in a P5Q Deluxe (no issues in 2 months running 24x7 and 4 modules).
Just tested each stick individually. Seems good to go on that side.
I did set tRC back to auto. I noticed that if I bump the timing to 5-5-5-12-5 in bios the machine allowed me to OC the CPU further. Sounds like that was the culprit?
Set your first four timings to 5-5-5-15 with 2.1v and leave the rest at auto until you get your OC stable then try and tweak the timings again. Install CPU-Z and run it for the SPD on your memory.
