XFX 790i ultra p07 bios problem
Okay, so I've got a big problem since I bought this computer that I thought was going to be pretty awesome and still give me room to upgrade later but now won't do crap. Let me first tell you what i got then I'll explain the problem.
>xfx 790i ultra
>intel q6600
>Patriot PC3 10666 DDR3 (7-7-7-20 1333)
>Two xfx 8600gt XXX
Everything was running good. It would only freeze every once in a while. However, it would always freeze if I tried to benchmark. Nforce tools would never let me overclock or underclock. All this was before I tried to update the bios.
I figured updating would fix these problems. So i burnt a CD and updated to p07 basically from the original bios. Immediately after that when windows would get to the desktop
it would freeze. It has freezed everytime since then. I have adjusted the voltages, no change. I even flashed back to the original bois. Still freezes.
XFX told me I should reload windows and see if that fixes the problem. But I hate to loose everything I got and also I can't just go spend 80 bucks on a new hard drive just to see if that's the problem.
Someone please shine some light on this situation.
5 answers Last reply
More about 790i ultra bios problem
  1. Welcome to the forums!
    Run memtest86+ and hard disk diagnostics from the manufacturer.
    Try loading in safe mode.
    Could be a bad driver or a bad motherboard if problem persists in safe mode.
  2. Question: You haven't OC'd right?
    I think the issue is the "it only froze a couple of times". Thats my warning light right there.
    At this point, your best bet is to re-install windows, especially if you can't get into safe-mode.
  3. Try reflashing to P06.
    I did not like 07 and reverted back to 06.
    Also, try "unlinking" the ram/fsb to see if it helps.
  4. I can't get into safe mode and I tried removing one stick of ram and then then other to see if that would help and neither helped.
    I was trying to avoid restarting windows but I will try that soon if I can't find a solution.
    I don't think going back to p06 will help because it was running ok on p01 before I updated to p07 but when I go back to p01 it won't run anymore, and I already tried unlinking. No change
  5. One more update. XFX just asked me to send it in so I guess they think its the board. Thanks for your help guys!!!
Motherboards BIOS
