Tom's Hardware > Forum > Overclocking > Graphics Cards > Radeon HD 4870 peltier cooling???
Forum Overclocking : Graphics Cards - Radeon HD 4870 peltier cooling???
I have a 177watt peltier, a power supply to fully power it, and a 145watt heatsink that i will be putting a twice as powerful fan on, the heatsink also has heatpipes is a Phenom 2.5ghz heatsink. Now i was wondering if and how i could put this peltier on my asus radeon hd 4870 video card, so i can greatly overclock this, i already know very well about waterproofing and sealing peltiers, i'm just not sure on how to attach this heatsink on here?
Sponsored Links
not again :D, you need to find a hd4870 compatible water block very important as a 400w tec would rape any air cooler, then its a pain to mount mostly is all custom made but good luck :D,
http://www.xtremesystems.org/forum [...] y.php?f=94
this is the better place for this topic not many people here even know what a tec is and we all replied to your last thread
Reply to richardscott
its a 177watt not a 400watt, ya i'm at my gf's and i'm very bored so posting about this until i get home is all i got to do... sry if ive got to many posts going.
Reply to gadgeteer123
ok is the pelt a 177w Qcmax pelt? if not then you need a bigger pelt for a HD4870 as it has a tdp of over 160w. next problem you still need water cooling as a 177w Qcmax pelt will need to be cooled by a min of 400w+177w so thats air coolers out of the way.
next problem any gpu stand alone block will be fine but, it will need to be insulated and a require a 360mm rad just for the 1 gfx card
^Yeah, the OP has a 177W Qmax. And OP you NEEED water cooling on the TEC. Period.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
There are 1189 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
