After installing a new motherboard in my system (upgraded to MSI K9N2 SLI Platinum), I have noticed a new, very unpleasant sound coming from my system. It is not particularly loud, but high-pitched and very annoying, somewhere along the lines of a whiny buzzing/whirring sound, maybe kind of like a mosquito. It will change in pitch and intensity, sometimes it goes away entirely. The new motherboard was the only hardware change, all other components are the same. I removed the side panel and turned my computer on and stuck my head in there to see if I could tell where the sound was coming from, and it seemed to be coming from the power supply. It is a Rosewill 450W with two fans. It honestly doesn't really sound like its coming from a fan, which of course is the first thing I would assume when it comes to pc noise. It is interesting to note that the noise seems to correlate with software activity, for example, I was running PCMark05 and when one of the tests was running there was no noise, but then when that test finished and it was moving on to the next one, it started up again (I have observed instances like these enough to conclude that it's not a coincidence. Obviously, there is a lot of current running through the power supply, is it possible that this could cause an annoying buzzing sound? Thanks in advance!
