Tom's Hardware > Forum > CPU & Components > CPUs > ASUS AMD Cool 'n Quiet graphic monitor misalignment. Please help.
Forum CPU & Components : CPUs - ASUS AMD Cool 'n Quiet graphic monitor misalignment. Please help.
Hello I have AMD cool 'n quiet enabled and it is working on my 2.2GHz 4200+.
But the display bar/program doesn't show voltage because the wording is too far low on the picture and is cut-off.
This same problem also means that the numbers that display clock speed are not in the boxes they should be but shifted down and right in what I can only know as some sort of graphics error.
I don't have this 'misalignment' problem on anything else on Windows XP I'm running.
It is still quite difficult to understand this from my descriptions so I have taken screenshots of what I have now and what it should be like (from ASUS website).
But I don't know how to post these screenshots on this forum. They are ready and shrunk to an acceptable forum size in JPG. Please tell me how to do this first.
I use the latest Firefox version.
Thanks for help if you can help.
Sponsored Links
If you mean Asus PC Probe v2 then I would ditch it - it seems pretty buggy and sometimes uses far too many resources.
I use the AMD power monitor from the AMD site http://www.amd.com/us-en/assets/co [...] or_123.zip
Smaller, allows you to change the power profiles on the fly very quickly and (so far) has been totally reliable.
HTH
Reply to kyzarvs
There are 1042 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
