I'm wondering if my power supply will be able to handle it though - it's rated wattage is 460, but I'm not sure what brand it is (and I'm having a hard time finding out from dell support webpage). The comp is a pre-made dell xps gen3, with a dual core pent4 at 3.4 GH, and 4g ram (it was meant to be a work comp originally...). Looking at the various calculators for power supply it seems like it should be fine - the new card should take another 40 extra watts or so, but it would be kind of close. I also read on the manufacturer's site that the card requires 400 watts... I assume that was meant for a generic system+plus this GPU, not the card itself.
Are there any tools to identify how much power I'm actually currently using so that maybe I can get a good estimate on how much extra I have? Other then these calculators that are estimating?
Alternatively if someone can point me towards a less power-hungry worthwhile card that would be fine too (I only really want to run warhammer online well after all).
This will give you an idea http://extreme.outervision.com/psucalculatorlite.jsp Just add what you have in your system to th etabl eand it will give you an estimate of what you are using. Yes it is system +card and not just system. Dell PSU's are pretty robust and should handle a 8800gt but i would try and find out exactly what the +12Vrail ha son it in AMPS.
Okay I'm seeing about a 30-40 watt difference between the 2 cards. I'm findind it hard to see the actual specs of the PSU too, so don't feel bad. I believe (through my searching) that this PSU also is a server PSU too and is manufactured from Delta PSU, which is a good thing.
Using the Power Calculator, I get a total of 397 watts. That is with Pent D 3.4ghz/8800gt/4x1 gb's DDR/2 DVD drives/1 HDD/2 USB devices/90% system load and 20% capacitor aging (2 years worth of aging).
I think you should be okay with the 8800gt. If you have other GPU power questions, than look at the GPU Power consumption list. I have it in my signature line too.
P.S. I think the 4850 would be your next step up on the GPU level, but would be about 32 watts, which might be okay.
Message edited by lunyone on 09-14-2008 at 11:56:23 PM
Oh, you mean that label should be the same for my machine? I thought you were just putting up a random one as an example, thanks .
I'll open up my case to double-check in any case a bit later. The power supply is positioned a bit odd along the length of the tower in it's own compartment and you can only see one side of the label clearly so it might be a bit of a pain.
Thanks though, I guess I'll go with it, especially now that there is a rebate until sept 30.
I made it, I've got photos of a few Dell psu labels, just hosted the one in question.
Yeah, it's very difficult to find any information on that PSU, so that is why I asked where you got it. I wish there was a place online to browse through the Dell PSU's somewhere, but I'm sure they don't want everyone having access to their "proprietory" PSU's/mobo's/etc.
