This will sound old... but I've been reading these forums for the past couple weeks contemplating building myself a system and the more I read the more I want to build my own rig. I'd like this to be around $800... cheaper is better.
I plan on using this computer for work (I do simulation work, run Matlab, Mathematica), personal media (some video encoding, simple watching movies and listening to music), and also I like to play games (WoW, Witcher, Supreme Commander, Hellgate: London, SC2/Diablo3 when they come out). Sometimes I even do all these things at once... not well mind you but I try.
I am using a 22" Acer AL2216W (1680×1050, 5ms response). I don't think I'll do CF but I'd like to keep the option open even if the 2nd card only uses PCI-e 1 and not x16. I will OC eventually, I'll do this earlier than CF.
So here are the parts I was considering for my purposes:
CPU - Q6600 Kentsfield 2.4GHz Quad $190
http://www.newegg.com/Product/Prod [...] 6819115017 Read it's a good OCer and will last me for a good while... I know C2D is better for games but I think the quad is better long-term and multitasking.
Mobo- Here is where I need some help... I'd like to OC in the future and consider CF. The cards I've been looking at are:
1. Biostar TP43D2A7 http://www.newegg.com/Product/Prod [...] 6813138122 $90
I imagine this one doesn't have CF support being a P43 board but I read it's a good for OCing.
2. Asus PQ5 Pro http://www.newegg.com/Product/Prod [...] 6813131299 $140
I know this will do CF but I don't know if it's any good at OCing.
Case- I want something with good cooling but not really flashy (I'm not into that whole LED thing):
COOLER MASTER RC-690 http://www.newegg.com/Product/Prod [...] 6811119137 $85 ($70 MIR) Has plenty of fans and looks nice. It does have the PSU on the bottom which may or may not be a problem. Also does this have enough space for aftermarket cooler (say the Rifle or Arctic cooler 7?).
PSU - I think I calculated about 350W or so without OC and a single GPU... I think 600W should do fine for OC.
1. OCZ StealthXStream 600W http://www.newegg.com/Product/Prod [...] 6817341010 $80 ($45 MIR) Has 4 12V rails @18A each... and at $45 after MIR I can't see a better option. Is this a good PSU company?
Case/PSU combo- Not sure this is the best way to go but I'm throwing it out there....
1. Antec Sonata III 500W http://www.newegg.com/Product/Prod [...] 6811129024 $100 Saves ~$15 from the separate PSU/case but has fewer fans and less wattage.
HDD - I have a SAMSUNG Spinpoint F1 HD103UJ 1TB 7200 RPM that I use as an external with my laptop that I could use. What I was thinking of doing was to get a small HDD for OS/programs and use this 1TB drive for data files and to easily move data b/w my laptop and desktop. I don't know what's a good HDD to get though.
hey guys... any help would be appreciated... here's an abridged version:
cpu- q6600
mobo - asus pq5 pro
video card - asus hd4850
ram - ocz titatium 2x2GB
psu - OCZ StealthXStream 600W
case - COOLER MASTER RC-690
CPU cooler - ARCTIC COOLING Freezer 7 Pro
Go with the rifle if it'll fit, and the retention bracket. Much better cooler, although larger. I see no major problems with it since you won't be doing any intensive gaming or anything. Good case for cooling w/o led or side panel.
