Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > Visiontek 4870x2 noise while under load. Help?
Forum Graphics & Displays : Graphics Cards Visiontek 4870x2 noise while under load. Help?
At first I was trying to figure out some info about a high pitched noise when this card is under any kind of load. It's a cross between a whine and a humming sound kinda like if something is rubbing against a fan Which seems to be normal for high end cards for the most part?
I'm not worried about it as much since I'm starting to have another issue with my card (I think) After playing COD4 for about 15-20mins I get a constant beep coming from the system. Something 100% different from this humming. Its very hard to pinpoint the source but I think its the video card because the second I tab out to windows it stops. While this is going on I have no performance issues. The system seems to be running fine?
This is very frustrating. I am trying to contact Visiontek about this but I'm still waiting for a reply from them. I'm going to push for an RMA and quite frankly I hope it's the card. I really don't want anything else to go wrong with my new build. :fou:
Anyone have any ideas of whats going on?
System:
Mobo: GA-EP45-DS3L
CPU: E4500 @ 2.93ghz
HSF: CoolerMaster Hyper 212
RAM: G.SKill DDR2 1066
HD: WDAAKS 640
OS: Windows Vista Ultimate x64
PSU: Silverstone DA800 800w
VIDEO: Visiontek 4870x2 [using drivers from cd]
Message edited by wutlol on 09-15-2008 at 03:44:20 AM
Reply to wutlol
Looks like defective fan. Beep is an error code, in this case, most likely from overheating. Rma it.
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
- 0 +
The beep code is coming from the mobo or the card itself?
Reply to wutlol
Try to isolate the sound, it could be coming from your mobo or your psu, as in a cap screaming
------------------------------ If we lose this freedom of ours, history will record with the greatest astonishment, those who had the most to lose, did the least to prevent its happening
Reply to JAYDEEJOHN
If the sound you're hearing is like a sound of a jet turbine engine. It should be normal...... Otherwise, try downloading RivaTuner and then using that program, set your video card fan to 100%. Then lower it to 50%, if the fan noise has been greatly reduced, I think it is normal.
PS. I think the constant beeping is NOT from your video card but from your motherboard, I think it's overheating, to verify download one of the system temperature monitoring tools and see it immediately after ALT+Tabbing out of the game. If it's 60 degrees celsius it could be causing the beeping sound. Which is your CPU warning.
Reply to stridervm
- 0 +
Good point. On most motherboards, the top pciex16 slot is right next to the northbridge heatsink. I've always wondered how heat rising from the belly of the card's pcb would toast that chipset. :na:
Reply to dagger
- 0 +
Well I just tabbed over and the motherboard temp was 39c. core 1 and 2 were at 41c. Video was 72c fan speed at 55%. Tabbed back over and played for 10 more mins. Then the sound returned. After about a minute or so of me trying to figure out where its coming from it went away on its own. Without me tabbing back to windows? :heink:
Reply to wutlol
- 0 +
Wow. I just found out where the sound is coming from. My UPS battery back up. :lol: I guess all this juice my system is sucking up is straining my battery backup.
Reply to wutlol
Im thinking its a capacitor making that noise
Reply to JAYDEEJOHN
- 0 +
A capacitor could be making the first noise I was hearing but the prolonged beep was coming from my UPS battery back up. I just happened to look down and the red fault light was flashing. I unhooked it and plugged the computer into the wall directly and I have yet to have an issue yet. Other than the clicking and the humming which is normal from what I hear other people say. I rand 3dmark 06 and my scores actually jumped up 200+ points or so.
Reply to wutlol
Sounds like your UPS was undervolting your system
Reply to JAYDEEJOHN
High pitched noises relating to cpu, ram, or graphics cards almost always comes from the capacitors. My card does it noticeably when the frame rate climbs into the thousands during loadings, can barely hear it even if I try during gaming. A few of the 680i boards from evga were particularly known as "squealers" when the cpu was under load. Shouldn't be anything to worry about unless the noise is so constant and loud that it impairs your gaming experience.
Reply to LAN_deRf_HA
I have the same problem right now and it results in overheating of the video card followed by a resultant crash. The high freq squeal comes from the video cad AND the power supply. When it happens, the auxillary power connectors for the video card heat up as well. This is my second video card and motherboard so I'm beginning to think the culprit is the power supply. Unfortunately, I think it's a flaw in the design of the PS since I have dual power supplies and both exhibit the same issue when I roll the video/MB load over to it. Cheap power supplies....
Reply to jbrinkley
Hello,
I'm an electronic student from Iran . The problem refers to the psu. As you said the sound comes when you play game then your psu goes under pressure.
I think your power has for 12v lines and their ampere is not enough for your graphic card . Try to you use new versions of power supply with high ampere capacity that use two 12v lines . The sounds comes from PFC core in your power supply that shivers during game to provide enough volt ampere for your graphic card, and since your vga takes more ampere , the PFC goes under pressure and makes sound.
fortunately. It does't make any change in fix voltage of your system .
You can send your PSU to the company and change a new version if They support.
Bob's you uncle!
My system
Quad 6700
Asus P5qc
2* ocz 800 working in 1.9 v clokced
club 4850
case Tuniq 3
hdd 500 maxtor
green gp 685b real power supply
http://www.green-case.com/products/power/index.html
Reply to Anonymous
THANK YOU!
I've had the same problem for a while now and I never thought to look under my desk at the battery backup! I have cruised tons of forums and the almighty google searching for an answer, and sure enough 10 minutes into gaming when I started to hear the beep, I looked under the desk and saw the little red light was on!
That makes me feel better, Thanks again for that. Whew, I thought my computer was on the verge of being toasted!
Reply to Anonymous
There are 1645 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 5 hours ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
