I bought a Western Digital Elements 1TB external hard drive. When I plug it in, Windows detects it as a "WD10EADS" but as far as I can find, all retailers and even the WD site say this is an internal hard drive. Complete model number: WD10EADS-00M2B0.
The access speeds are horrid. A file of 700mb takes about 10 minutes. Usually Windows copies about 600mb of it straight away, after that the speed just drops and drops and drops while the HD access light is flickering.
I run Windows 7 64-bit. My laptop runs Windows XP 32-bit, and has the same problems with it. I tried formatting the drive to both FAT32 and NTFS, same problem.
I have five other external WD hd's: two 120gb passports, two 500gb elements (older model, silver) and one 1TB passport. None have this problem.
Because the above mentioned harddrive is an external drive (USB) but every bit of information I can find says it should be an internal drive, I fear that something has gone wrong with perhaps configuration/firmware of the drive or putting the wrong drive in the external case. Maybe it wants to act as an internal SATA drive, but it is connected through USB.
Thanks for any and all information.
