Amid all the Computex fuss it’s important to remember that outside of Taipei, the world goes on. It’s with this in mind that AMD today announced the launch of AMD Changing the Game, the first initiative from the newly formed AMD foundation. Read more
Microsoft today released updated beta versions of its programming tools for building Web services and workflow-enabled applications on Windows. Read more
his morning saw the official opening of Apple’s latest flagship store in downtown Boston. Read more
The Reclusa gaming keyboard is yet another product that was born through the cooperation of the Redmond-company and Razer, a company that has specialized itself on developing gaming peripherals. Read more
We tightened the budget on this month’s enthusiast-level system while loosening our belt for the low-cost gamer box by a similar percentage. Today we gauge the effect of these changes on performance and value and compare to last month's machines. Read more
On this, the second day of our System Builder Marathon, Don turns down the price tag of his mid-range build looking for a sweet spot just above the $1,000 marker. Let's see what sort of hardware he found for it! Read more
This month's System Builder Marathon is all about your feedback to us. We've revamped our entry-level and mid-range PCs with new price points. Let's kick things off with what we think is the best value at a $625 price point! Read more
Where were we in 2008 and where are we heading in 2009? In his State of the Personal Computer address, Alan Dang shares his insights as a user of three different platforms: Mac, Windows, and Linux. Read more
Tom's Hardware Forums »
Homebuilt Systems
New System Build »
Help with building gaming rig under £700
| Bottom | |
| Author |
Thread : Help with building gaming rig under £700
Profile: newbie
More Information
Hey i know this probably been asked a billion times but, Well im 18 years old, wanting to build a gaming rig.
Related Product
Profile: old hand
More Information
Look into 780i. EVGA, ASUS, MSI, etc. 780i can do 3-way/dual SLI x16 and Yorkfields. Not a bad overclocker to boot. 3ghz is doable even on stock cooling.
Profile: newbie
More Information
Thanks, I think i will go with that board, i found one on dabs for £150
Profile: stranger
More Information
The Q6600 is a fine choice. Still, you will be using a platform that will be obsolete in the near future.
Profile: newbie
More Information
Im very impatient though and just want to get a new computer up and running i prefer using it than building it but i would enjoy both.
Profile: newbie
More Information
UPDATE --------- sorry for the double post ,,
Profile: old hand
More Information
It's a misconception that a cpu must be overclocked. It doesn't have to be. A stock Kentsfield is fine for those tasks.
Profile: newbie
More Information
Thanks, I wont necessarily overclock to begin with then,
Profile: old hand
More Information
The rest looks good, but I'd get an aftermarket overclock like Freezer 7 Pro or better yet Xigmatek HDT-S1283 or HDT-SD964 + mounting kit. Cuz if you decide to install a new cpu cooler after the pc is set up, it'll be a hassle to remove everything. Do it right now so when you overclock, you won't have to open up the case.
Profile: newbie
More Information
Thanks, I will get a 750W corsair PSU from dabs,
There's a statistic or bench for everything.
Profile: nimble knuckle
More Information
sigh.... evga 750i FTW is all you need! who has 1k to spend on 3 graphics cards i mean seriously... do you need dual gigabit ethernet? i cant imagine why... if not then why not save some cash and get the 750i -_-
Profile: addict
More Information
Couple of things: - You might be better served by a 4870 system. You need to buy an 8800 Ultra to get on a par with them. (£170 from ebuyer). As far as I can see 8800GTX's are the same price as a 4870 and are considerably outdated technology. - Corsair 750TX will do that system. Good choice. - At that point you can go with an Intel P45 chipset which perform better than the nVidia ones. Try and Asus P5Q-Pro. (£85 ebuyer, save £50). P45 will allow for Xfire, but if you want to do that straight away you might want to think about an X48 chipset that has 2x PCI-e x16 lanes. - You will only need DDR2-1066 even for a big overclock. It will be cheaper than that PC9600. Also go for 4Gb and a 64bit OS. You will see more benefit from more slower RAM and a 64bit that less faster RAM and a 32bit. Jeremy Edit: Extra info I've just picked up elsewhere that you will only see a 5% graphics benefit from an X48 motherboard over a P45 in crossfire. Given the extra cost it isn't worth it. Go P45. Message edited by jpdykes on 08-25-2008 at 01:07:11 PM |
You tell me what I do.
Profile: Eternal Poster
More Information
this is what i done for a friend recently for about £700 check it out
Profile: addict
More Information
Not sure about that spec iluvgillgill.
Profile: journeyman
More Information
Might consider a higher clocked core 2 duo E8500 wolfsdale as most games are not optimized for 4 cores.
More Information
