News
Chaintech and MSI launch SLI-ready GeForce 7600GT graphics cards
Published on March 10, 2006
Walton Chaintech and Micro-Star International (MSI) yesterday launched their respective graphics cards based on the Nvidia GeForce 7600GT graphics processing unit (GPU) with Scalable Link Interface (SLI) multi-GPU technology. Read more
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
PC TV survey gives away 21" widescreen LCD, HDCP graphics card
Published on August 17, 2006
Jon Peddie Research is currently running a survey on "PC usage and desires." Read more
Nvidia Contract Makers In Taiwan Low-key Over Defective Chip Reports
Published on July 07, 2008
Nvidia's Taiwan-based graphics chip contract makers are being low-key after the US chip designer informed investors on July 3 that will take a charge of US$150-$200 million related to expenses stemming from issues discovered with die/packaging materials used in previous generation notebook products. Read more
Latest Reviews & Articles
The Hardware Behind Overdrive
Published on November 18, 2008
Our worldwide overclocking championship has begun and we wanted to introduce you to the everyday components our teams will be tweaking to supersonic speeds in a bid for a shot at $5,000. Read more
Synology's DS408 Reviewed: Fast NAS For Pros
Does a NAS device with high data transfer rate and a Web interface that is easy to configure actually exist? Synology shows how it should be done. But the enclosure is not without its faults, either. Read more
How To: Get A 4 GHz Dual-Core For $120
Published on November 17, 2008
Intel’s 45 nm Core 2 serious is known to boast substantial overclocking margins, and the entry-level E7200 with 3 MB L2 cache costs less than $120. We'll show you how to get close to 4 GHz from this little gem. Read more
Team USA Emerges In Round One of Overdrive
After a long weekend of intense benchmarking with nearly 1,300 liters of liquid nitrogen, one team emerged victorious. They’re on their way to Paris to represent the United States against four other international teams. Show them some support! Read more
  Tom's Hardware Forums » Graphic & Displays » Graphics Cards » Problem with 7600GT
Problem with 7600GT
Word :   Username :
Bottom
Author
 Thread : Problem with 7600GT
Profile: stranger
More Information
I need help figuring out what is wrong with my XFX 7600gt xxx (with factory OC). I was playing Battlefield 2 and start seeing really bad artifacts, some seconds later a BSOD and reboot. The error report from windows said the error was from the Graphics card. Now there artifacts all over windows, some icons arent shown, videos are hard to see. With the ati tool in the "look for artifacts" option it shows artifacts just when the test starts, it doesnt get over 60C before getting artifacts. BSOD are getting more frequently and wihtout running any 3d application. I tested an old card on my pc and worked fine. I cleared the dust out of the fan. Fan is working.Tried reinstalling drivers and nothing. I think my card is dying, but could it be something else? or at least any idea of what could have done it?
I have thought of some reasons but dont know if there is a way to know..
Could it have overheated once and damaged the gpu permanently??
Could my card be underpowered? (7600gt doesnt need to be connected to PSU) .
Does playing BF2 in full settings with 2x AA 1280 x 1024 was too much too ask for a 7600? lol
System specs
Motherboard Aus M2n4-Sli
Athlon xp x2 3800+
2GB DDR2 800
Windows xp
Any more tests i could do??? Thanks for the help.
Related Product
Profile: nimble knuckle
tbh, your card probably is dying... its pretty old and it may have been damaged some how with something you were doing
i've heard stories where someones stock heatsink works fine up to a certain temperature... and then just completely sucks and then the chip gets messed up
to me it sounds like your card is dying....
if you decide on getting a new gpu, i'd get a 4850 if you want current technology or get an 8800 GS which are about 70 bucks right now, which would also serve your purposes
Profile: addict
More Information
Sounds to me like the the card is dieing. Not much you can do. Try using ATITool to underclock the gpu and memory and see if you still get errors.
Bux.to | .view .click .make money
Profile: journeyman
More Information
That does indeed sound like a dead card.
Something similar happened to me back in the days when I had a trusty 5200.
We had a really hot summer, and one day I started noticing massive triangles jutting out of mesh seems... where previously there was none.
I didn't want to accept it, but deep down inside I knew my card was dead.
A few weeks later my entire system crumbled, and then I had no choice but to upgrade.
Profile: stranger
More Information
I underclocked it with ati tool, to my surprise i was able to leave the core clock at 650 but had to underclock the memory to 500 (originally 800) and had no artifacts for 5 min and im not seeing artifacts on windows anymore. What does this tells you? can it be fixed? should i go play battlefield 2? :ouch:
Profile: addict
More Information
Obviously, it tells me there is something wrong with the memory. You should be ok underclocking it with ATITool. Test it and see what is the maximum it will be stable at. Then maybe bump it down just a little more for safe measure. But it may still die eventually. Does the video card's heatsink also cover the ram? It's possible the ram is overheating. You could try removing the heatsink and replacing the thermal pads/ grease for the ram chips. If they are not covered, you could add ramsinks to them.
Profile: old hand
More Information
+1 for orangegator's idea about reseating the heatsink.
As far as thinking your 7600gt is not getting enough juice, I doubt it. I had a 7600gt and I never had any problems with it even with a semi-decent psu. It really doesn't use a lot of power.
It just sounds like it is time to replace it. Too bad it is probably out of warranty, otherwise you could probably get a new card for nothing.
But since you're probably in the market for a new graphics card, I'd go with the ati 4850 or a minimum of a 9600gt. I have a 9600gt and I love it in comparison to my 7600gt.
How could I go from the king of RockN'Roll to this
Profile: old hand
More Information
Yup sounds like overheating RAM. Like orangegator says, try reseating the heatsink. If it doesn't currently cover the RAM chips then either your RAM is dying, or something on the PCB died so your RAM isn't getting enough voltage. Either way that would warrant looking into a new card.
Don't give up. Visit votenader.org Athlon 64 X2 5000+ @3.1 Brisbane | GIGABYTE GA-MA790X-DS4 | 2GB Mushkin DDR2 800 | Plextor 760A| Asus EAH3850 G/HTDI/512M | WD 1TB Black| Fortron Blue Storm II 500W | Creative Audigy 2| Win XP Pro & Vista Buisness 32bit
Google Ads
