I just got a 750 watt power supply installed it and the computer can seem to stay on for more than about 40 min or less. The computer worked fine with a okia 500 watt power supply and only 18a on 12v. The 750 watts is fromm alienware but the label says Newton Power ltd MODEL: N750E-00. 750 watt max +12VA 18A, +12VB 18A, +12VC 18A, +12VD 16A, +5V 16A, -12V .2A, +3.3 30A, +5VFP 3A
Computer Specs
AMD Phenom 9750
asus 9600 gso 384mb overclocked
liteon dvd writer
western digital 750gb
Viva VGA/CPU Liquid Cooling System for video card only
motherboard 7050m
COOLER MASTER GeminII cpu heatink
4 antec tricool 120mm
It has 4 pci-e connectors 2 on each line coming from the power supply. I acant figure out what is going wrong. Im thinking the power supply is defective. Can you guys help me out thanks.
What are your temps? Is anything overclocked? Reset BIOS to defaults. Reset any overclock to stock. Is that a micro board? Maybe its chipset needs better cooling.
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
Motherboard is ECS 7050M-M V2.0
case temp about 39c
cpu temp 19c
gpu 43 c
the video card is factory overclocked other than that everything is normal. I didn't have these problems with a 500 watt okia power supply.
